regarding serial port communication
gopalakrishnan
PostPosted: Thu Jul 08, 2010 3:10 am     Reply with quote
ccs compiler version: 4.053
pic ic no:16f877A
hai to all, i tried to establish serial port communication through c4 and c5. where as c4 is the transmit and c5 is receive. Like this way when i loop back the data from c4 and see the received data to the lcd . This is my logic. I already establish communication through c6 and c7 i received the data correctly. Where as i am unable to communicate through c4 and c5. This is my following code. Kindly go through it and give some suggestion.
#if defined(__PCM__)
//#include <16F877A.h>
#include <stdio.h>
#include <string.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use standard_io(B)
#use standard_io(C)
#use standard_io(D)
#define LCD_ENABLE_PIN PIN_B0
#define LCD_RS_PIN PIN_B2
#define LCD_RW_PIN PIN_B1
#define LCD_TYPE 2
void lcd_init();
void lcd_cmd(cmd);
void lcd_data(data);
unsigned char cmd,data,bv;
  set_tris_b(0x00);
  set_tris_d(0x00);
  //set_tris_c(0x20);
   //output_d(0x00);
   //output_c(0x00);
   //output_b(0x00);
  //#USE RS232(BAUD=9600, XMIT=PIN_C4,RCV=PIN_C5)
  #USE RS232(BAUD=9600, XMIT=PIN_C6,RCV=PIN_C7)
  printf("I");
  bv=getc();
  data=bv;
  lcd_init();
void lcd_init()
       cmd=0x38;//
      lcd_cmd(cmd);
      delay_us(1640);
      cmd=0x0E;
      lcd_cmd(cmd);
      delay_us(1640);
      cmd=0x01;
      lcd_cmd(cmd);
      delay_us(1640);
      cmd=0x06;
      lcd_cmd(cmd);
      delay_us(1640);
      lcd_data(data);
      return;
   void lcd_cmd(cmd)
      output_d(cmd);
      output_low(PIN_b2);//rs
      output_low(PIN_b1);//read write
      output_high(PIN_b0);
      delay_us(1640);
      output_low(PIN_b0);//enabel
      return;
   void lcd_data(data)
      output_d(data);
      output_high(PIN_b2);//rs
      delay_us(1640);
      delay_us(1640);
      return;
thanks in advance
with regards
K.gopalakrishnan
gopal_kmu54@hotmail.com
