Problems with the UART of the PIC24F
frankcr
PostPosted: Wed Jul 07, 2010 11:23 pm     Reply with quote
Hi, I have problems with the uart of the PIC24FJ128GA006. I need to connect the uart with a serial/usb converter to save information. But I don't know if my code is the problem or the voltage levels is the problem (the converter use 5V and the PIC use 3.3V ). My code is:
#include <24FJ128GA006.h> //MICROCONTROLADOR UTILIZADO
#device adc=10 //ADC 10 Bits de presicion
//************************ FUSES **********************
#FUSES ICSP1                    //ICD uses PGC1/PGD1 pins
#FUSES NOWINDIS                 //Watch Dog Timer in Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
//#FUSES FRC                      //Internal Fast RC Oscillator
#FUSES XT                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES NOPR                     //Pimary oscillaotr disabled
// ********************** CLOCK ************************
#use delay(clock=8000000)
#use rs232(UART1,baud=9600,parity=N,bits=8) //
#define RTS PIN_B12  //Clear to send
#define CTS PIN_B13 //Request to send
//Variables del RTC, a mandar o leer
int seconds=0;
int minutes=0;
int hours=0;
int day=0;
int date=0;
int month=0;
int year=0;
int control=0;
int time=0;
//Variables de los datos de los sensores
float adchin=0; //TEMPERATURA Y HUMEDAD
float adctin=0;
float humedadin=0;
float temperaturain=0;
float adchout=0;
float adctout=0;
float humedadout=0;
float temperaturaout=0;
float promediotin=0;
float promediotout=0;
//Variables utilizadas en el comunicacion con el UART
static char texto_rs232[50]; //cadena de caracteres para el rs232                 //70
static char PRINT[36]; //SE ESCRIBE EN EL ARCHIVO DE TEXTO 'MEDICION.TXT'
int1 dato_recibido=0,wait_datos=0;
int cont_rs232=0;
int cont_comand_rs232=0;      //variable del explorador
//Metodos de VDRIVE Y UART
void inic_host(void);
void CARACTER(void);
void recepcion_serial(void);
void wait(void);
void serial_sendbyte(unsigned int8 TXbyte);
int1 buscar_dispositivo(void);
void retire_dispositivo(void);
void OPW_FILE(void);
void WRF_FILE(void);
void CLF_FILE(void);
void main(void);
// **************** INTERRUPCION UART1 *****************
#int_RDA
void  RDA_isr(void)
   disable_interrupts(INTR_GLOBAL);
   recepcion_serial();
//******** ENVIA UN CARACTER AL PUERTO SERIE ************
void serial_sendbyte(unsigned int8 TXbyte){ //METODO PARA ENVIAR UN CARACTER
      while(input(CTS));
      putc(TXbyte);
//*********** **METODO QUE BUSCA MEMORIA ***************
int1 buscar_dispositivo() //BUSCA LA MEMORIA
   int1 dispositivo_encontrado=0;
   serial_sendbyte(0x0D);
         OUTPUT_LOW(PIN_E0);
         OUTPUT_LOW(PIN_E1);
         OUTPUT_LOW(PIN_E2);
         delay_ms(950);
   delay_ms(50);
   if((texto_rs232[0]==0x3E)){
      dispositivo_encontrado=1;
   return dispositivo_encontrado;
//******** METODO GUARDA CARACTERES RECIBIDOS **********
void recepcion_serial()
   texto_rs232[cont_rs232]=getc();      //Cada vez que llega un caracter
   ++cont_rs232;                //este se introduce en esta variable.
   dato_recibido=0;
         OUTPUT_HIGH(PIN_E0);
         OUTPUT_LOW(PIN_E1);
         OUTPUT_LOW(PIN_E2);
         delay_ms(950);
   if((texto_rs232[cont_rs232-1]==0x0D))   //Pregunta si ya se envio el ultimo caracter
      if(wait_datos){   //Espera que lleguen los 1024 bytes
         cont_rs232=0;
         wait_datos=0;
      if(!wait_datos) {    //Para que el contador no se recetee si se esta esperando leer los
         cont_rs232=0;   //bytes de un archivo
      dato_recibido=1;   //Bandera para el metodo wait()
      ++cont_comand_rs232;
//***** METODO ESPERA PARA RECIBIR TODOS LOS DATOS******
void wait() {  //ESPERA A RECIBIR EL PROM DEL MODULO
   delay_ms(25);
   while(!dato_recibido);
void medicion(){
   OPW_FILE(); //Abre el archivo de texto para escribir en el
   delay_ms(1);
   CARACTER(); //caracter correcto para escribir en la llave
   delay_ms(1);
   WRF_FILE();  //Escribir caracter en el archivo creado
   delay_ms(8000); //tiempo que garantiza una correcta medicion de ls sensores de humedad
   delay_ms(8000);
   CLF_FILE(); //Cerrar archivo de texto
void OPW_FILE() { //ABRE EL ARCHIVO DE TEXTO PARA ESCRIBIR EN EL
   serial_sendbyte(0x09);
   serial_sendbyte(0x20);
   serial_sendbyte("T");
   serial_sendbyte(".");
   serial_sendbyte("X");
void CARACTER(){ //36 Caracteres
   sprintf(PRINT,"%2x-%2x-%2x%2x:%2x:%2x%g%g%g%g",date,month,year,hours,minutes,seconds,humedadin,humedadout,temperaturain,temperaturaout);
void WRF_FILE() { //ESCRIBIR EN EL ARCHIVO DE TEXTO
   int x=0;
   serial_sendbyte(0x08);    //WRF
   serial_sendbyte(0x00);
   serial_sendbyte(0x00); //
   serial_sendbyte(0x26); //38 caracteres    //escribe 38d = 0x26 "bytes"
   while(x<36) { //36 caracteres de la funcion CARACTER
      serial_sendbyte(PRINT[x]);
      ++x;
   serial_sendbyte(0x0D); //2 caracteres que permiten hacer cambio de linea
   serial_sendbyte(0x0A); //36 + 2 = 38
  // wait();
void CLF_FILE() { //CERRAR EL ARCHIVO DE TEXTO
   delay_ms(200);
void retire_dispositivo() {
   while (buscar_dispositivo());
// ***************** INICIALIZA HOST USB *****************
void inic_host(void)  {
   output_high(RTS); //RTS
   while(input(CTS)){}     //espero que el VDRIVE2 busque el pic CTS
   output_low(RTS);       //le envio una respuesta RTS
// ******** Configuraciones de ADC, INT, WDT, TMRS *********
   setup_adc_ports(sAN3 | sAN4 | sAN5 );//Configuracion ADC: AN3-TEMP, AN4-HUM, AN5-CO2
   //setup_psp(PSP_DISABLED);
   setup_wdt(WDT_OFF);
   //setup_timer_0(RTCC_INTERNAL);
   setup_timer1(TMR_DISABLED);
   setup_timer2(TMR_DISABLED);
   setup_timer3(TMR_INTERNAL|TMR_DIV_BY_8);
   setup_vref(FALSE); //setup_vref(VREF_DISABLED);
   setup_oscillator(OSC_INTERNAL);
   set_timer3(2450);
   enable_interrupts(INT_RDA); //Habilita interrupciones de la USART
   enable_interrupts(INT_RDA2);
   //enable_interrupts(INT_EXT0); //Habilita interrupcion INT0
   enable_interrupts(INTR_GLOBAL); //Habilito Interrupciones
   //ext_int_edge(L_TO_H);
   OUTPUT_HIGH(PIN_E1);
   OUTPUT_HIGH(PIN_E2);
    delay_ms(5000);
     inic_host();//Inicializa el Host VDRIVE2
   int estado=0;
   while(TRUE) {
      switch (estado)
         case 0:
         OUTPUT_LOW(PIN_E0);
         OUTPUT_LOW(PIN_E1);
         OUTPUT_LOW(PIN_E2);
         delay_ms(5000);
            estado=1;
         case 1:
         OUTPUT_LOW(PIN_E1);
         OUTPUT_LOW(PIN_E2);
         delay_ms(5000);
         estado=2;
         case 2:
         OUTPUT_LOW(PIN_E0);
         OUTPUT_LOW(PIN_E2);
         delay_ms(5000);
            estado=3;
         case 3:
         OUTPUT_LOW(PIN_E2);
         delay_ms(5000);
            estado=4;//estado=4;
         case 4:
         OUTPUT_LOW(PIN_E0);
         OUTPUT_LOW(PIN_E1);
         while(!buscar_dispositivo());
            delay_ms(3000);
            estado=5;
         case 5:
         OUTPUT_LOW(PIN_E1);
         medicion();
         delay_ms(5000);
            estado=6;
         case 6:
            retire_dispositivo();
         OUTPUT_LOW(PIN_E0);
            delay_ms(5000);
           estado=7;
       case 7:
            delay_ms(5000);
            estado=7;
