Problem with LCD NOKIA 6610 and 16F87X
nemero16
PostPosted: Mon Jul 05, 2010 9:14 am     Reply with quote
hi I'm working with a Nokia 128x128 LCD and a PIC16F876A but I do not know if the screen controller is EPSON or PHILIPS ... this is the sample code I'm using but when I turn on the circuit, the screen lights (LEDs light), but remains the panel LCD black ... what is the problem? here's the code:
//// Russell Evolutions Inc.
//// Nokia 6100 LCD with Epson S1D15G10 Controller
////  sample initialization program for PIC16LF872 in CCS C  3-14-07
//// Based on Spark Fun Electronics Code by Owen Osborn 1-22-05
////   with thanks to David Carne of SFE for DISCTL help
////   and user 'Ttelmah' from CCS C forum for SSPEN bit idea for 9-bit hardware SPI
//// You are free to use this code for any purpose.
//// START OF HEADER FILE ////
#include <16F876.h>
#device adc=8
#FUSES XT                       //Crystal Osc (<= 4mhz)
#FUSES PUT                      //Power Up Timer
#FUSES NOBROWNOUT               //Don't Reset when brownout detected
#define LCD_RESET   PIN_C6
#define LCD_CS   PIN_B0
#define SPI_CLK   PIN_B1
#define SPI_DI   PIN_C4 //unused
#define SPI_DO   PIN_C7
#bit SSPEN = 0x14.5   // bit to turn on/off hardware SPI
// Epson S1D15G10 Command Set
#define DISON       0xaf
#define DISOFF      0xae
#define DISNOR      0xa6
#define DISINV      0xa7
#define SLPIN       0x95
#define SLPOUT      0x94
#define COMSCN      0xbb
#define DISCTL      0xca
#define PASET       0x75
#define CASET       0x15
#define DATCTL      0xbc
#define RGBSET8     0xce
#define RAMWR       0x5c
#define RAMRD       0x5d
#define PTLIN       0xa8
#define PTLOUT      0xa9
#define RMWIN       0xe0
#define RMWOUT      0xee
#define ASCSET      0xaa
#define SCSTART     0xab
#define OSCON       0xd1
#define OSCOFF      0xd2
#define PWRCTR      0x20
#define VOLCTR      0x81
#define VOLUP       0xd6
#define VOLDOWN     0xd7
#define TMPGRD      0x82
#define EPCTIN      0xcd
#define EPCOUT      0xcc
#define EPMWR       0xfc
#define EPMRD       0xfd
#define EPSRRD1     0x7c
#define EPSRRD2     0x7d
#define NOP         0x25
#define ENDPAGE     132
#define ENDCOL      130
////  START OF MAIN .C SOURCE FILE ////
//#include "<path to .h file cut from above>"
#use fast_io(C)
void pset(unsigned char color, unsigned char x, unsigned char y);
void spi_command(int);
void spi_data(int);
   int16 i;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED, 0, 1);
   set_tris_c(0x00);   // all outputs, can change to mask only hardware SPI bits if needed
   // reset display
   output_low (SPI_CLK);
   output_low (SPI_DO);
   output_high (LCD_CS);
   output_low (LCD_RESET);
   output_high (LCD_RESET);
   //init'd, now drop CS to send commands/data and raise when finished
    spi_command(DISCTL);  // display control
    spi_data(0x0C);      // 12 = 1100 - CL dividing ratio [don't divide] switching period 8H (default)
    spi_data(0x20);      // 32 = (128/4)-1 (round up) number of display lines for scanning
    spi_data(0x0C);      // 12 = 1100 - number of lines to be inversely highlighted
    spi_data(0x00);
    spi_command(COMSCN);  // common scanning direction
    spi_data(0x01);
    // 0 0 0 =   1 -> 80   81 -> 160
    // 0 0 1 =   1 -> 80   81 <- 160
    // 0 1 0 =   1 <- 80   81 -> 160
    // 0 1 1 =   1 <- 80   81 <- 160
    spi_command(OSCON);  // internal oscialltor ON
    spi_command(SLPOUT);  // sleep out
    spi_command(VOLCTR);  // electronic volume, this is the contrast/brightness
    spi_data(0x23);   // volume (contrast) setting - fine tuning
    spi_data(0x03);   // internal resistor ratio - coarse adjustment
    spi_command(PWRCTR);  // power ctrl
    spi_data(0x0f);      //everything on, no external reference resistors
    spi_command(DISINV);  // invert display mode
    spi_command(DATCTL);  // data control
    spi_data(0x00);   // normal display of page/column address, page scan direction
    spi_data(0x00);   // normal RGB arrangement
    spi_data(0x01);   // 8-bit grayscale
    spi_command(RGBSET8);   // setup 8-bit color lookup table  [RRRGGGBB]
    //RED
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    // GREEN
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    //BLUE
    spi_data(0);
    spi_data(4);
    spi_data(9);
    spi_data(15);
    spi_command(NOP);  // nop
  pset(0b11100000, 0, 0); // red pixel top left (also sets start of bulk write, see pset routine)
  for (i = 1; i <= 16900; i++) {  // 130x130 = 16900
      spi_data(0b11100000);   // fill screen red
  spi_command(DISON);   // display on
  while (1) {  // main program loop.  just blinks A0 to show chip is running
      output_toggle(PIN_A0);
void pset(unsigned char color, unsigned char x, unsigned char y){
//  sets the starting page(row) and column (x & y) coordinates in ram,
//  then writes the colour to display memory.  The ending x & y are left
//  maxed out so one can continue sending colour data bytes to the 'open'
//  RAMWR command to fill further memory.  issuing any other command
//  finishes RAMWR.
  x += 2;                  // for some reason starts at 2
  spi_command(PASET);   // page start/end ram
  spi_data(x);
  spi_data(ENDPAGE);
  spi_command(CASET);   // column start/end ram
  spi_data(y);
  spi_data(ENDCOL);
  spi_command(RAMWR);    // write
  spi_data(color);
void spi_command(int dat){
   output_low(LCD_CS);      // enable chip
   SSPEN = 0;               // shut off hardware SPI allowing direct access to SPI in/out pins
   output_low (SPI_DO);     // output low on data out (9th bit low = command)
   output_high (SPI_CLK);
   delay_cycles(1);         // send clock pulse
   SSPEN=1;                 // turn hardware SPI back on
   spi_write(dat);          // make PIC do the work for the command byte
   output_high(LCD_CS);     // disable
void spi_data(int dat){
   SSPEN = 0;               // turn off hardware SPI allowing us direct access to SPI in/out pins
   output_high (SPI_DO);    // output high on data out (9th bit high = data)
   spi_write(dat);          // make PIC do the work for the data byte
PostPosted: Mon Jul 05, 2010 12:27 pm     Reply with quote
You got that code from this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=37345
But that code is buggy. It's newbie code.
Picoholic provided a link to a Zip file of Nokia code on the Sparkfun
website (nokial6100_ccs_c.zip). Look for the link on that thread.
The Sparkfun code uses the hardware SPI pins, C3, C4, and C5.
The newbie that you copied has screwed up all those pins and
put them on Port D. There's no hardware SPI on Port D.
But then, you have continued this error by moving the pins
to a bunch of other non-hardware SPI pins.
My advice is, go back to the original Sparkfun code. I don't know if it
works, but at least it's using the real hardware pins.
nemero16
PostPosted: Mon Jul 05, 2010 1:47 pm     Reply with quote
ok I changed the ports and changed the code like this:
//// Marcus Russell
#include <16F876.h>
#device adc=8
#define LCD_RESET   PIN_C0
#define LCD_CS   PIN_C1
#define SPI_CLK   PIN_C3
#define SPI_DO   PIN_C5
#define DISON       0xaf
#define DISOFF      0xae
#define DISNOR      0xa6
#define DISINV      0xa7
#define SLPIN       0x95
#define SLPOUT      0x94
#define COMSCN      0xbb
#define DISCTL      0xca
#define PASET       0x75
#define CASET       0x15
#define DATCTL      0xbc
#define RAMWR       0x5c
#define RAMRD       0x5d
#define PTLIN       0xa8
#define PTLOUT      0xa9
#define RMWIN       0xe0
#define RMWOUT      0xee
#define ASCSET      0xaa
#define OSCON       0xd1
#define OSCOFF      0xd2
#define PWRCTR      0x20
#define VOLCTR      0x81
#define VOLUP       0xd6
#define TMPGRD      0x82
#define EPCTIN      0xcd
#define EPCOUT      0xcc
#define EPMWR       0xfc
#define EPMRD       0xfd
#define NOP         0x25
#define ENDPAGE     132
#define ENDCOL      130
#use fast_io(C)
void spi_data(int);
   int16 i;
   setup_adc(ADC_OFF);
   // reset display
    spi_data(0x00);
    spi_data(0x01);
    //RED
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    // GREEN
    spi_data(0);
    spi_data(2);
    spi_data(4);
    spi_data(6);
    spi_data(8);
    spi_data(10);
    spi_data(12);
    spi_data(15);
    //BLUE
    spi_data(0);
    spi_data(4);
    spi_data(9);
    spi_data(15);
//  finishes RAMWR.
  spi_data(x);
  spi_data(ENDPAGE);
  spi_data(y);
  spi_data(ENDCOL);
  spi_data(color);
but the result is always the same ... maybe a Philips controller? Where can I find some examples ready just as a test for the Philips controller?
