Posted: Thu Jul 01, 2010 2:33 am |
In the compiler directory, a file called 'fuses.txt'.
This gives the text description of what each fuse name used by CCS means.
However for the full data, no. It varies between PICs. You have to look at the data sheet for the particular chip. Example would be the 'CT' fuse, which on the older family PICs selects the low gain oscillator, rated to operate up to 4MHz, but exactly the same fuse name, on the later DSPICs, selects an oscillator rated up to 10MHz. There are similar small changes across the models.
