I'm having a problem in getting the correct source file names in the project files tree in the IDE (PCWHD ver 4.103). What I did was to move the original files to a new location and renamed the sources and project file. When I open this new named project it compiles fine but the source names for the files in the IDE project tree are still at the old names and I cannot update them to the new names or even delete them off. How can I get the project showing up with the current file lists, as I like th ability to click the source and have the IDE open the file for editing.
Posted: Fri Jul 02, 2010 9:01 am
Make a new project.
You can change all the references, through 'Options', then select 'project options', and delete each file in turn, and select the new ones. However it takes longer than just creating a new project.
