scrolling message board but animated problem
nemo41
PostPosted: Tue Jun 29, 2010 1:12 pm     Reply with quote
I sending working source code. My problem is to animate. Its up to down scroll message. I cant do it. Maybe write anybody?
Source code:
#include <18F452.h>
#include <string.h>
#FUSES NOWDT,WDT128,HS,NOPROTECT,NOOSCSEN,NOBROWNOUT,NOPUT,STVREN,NODEBUG,NOLVP,NOWRT,NOWRTD,NOWRTB,NOWRTC,NOCPD,NOCPB,NOEBTR,NOEBTRB
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
//#include <SHT75.c>
//#include <DS1302.c>
#define clock      pin_a0  //
#define latch      pin_a1  //
#define ds1        pin_a2  //
#use fast_io(a)
#use fast_io(b)
#use standard_io(c)
#use fast_io(d)
#use fast_io(e)
unsigned int16 adres_sec;
char  sutun_1[145],sutun_2[145],satir_1[320];
unsigned int yinele,data;
int t=0,degis=0,buton2=0;
char mesaj_1[]={'P','E','A','C','E',' ','I','N',' ','T','H','E',' ','W','O','R','L','D',' ',' ',' ',' '};
char mesaj_2[]={'B','A','R','I','S',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' '};
char mesaj_3[]={'P','E','A','C','E',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' '};
char mesaj_4[]={'P','E','A','C','E',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' '};
unsigned int karakter[]={0x3F,0x3F,0x48,0x3F,0x3f,0x00  //A 0
                        ,0x7f,0x49,0x49,0x49,0x36,0x00  //B 6
                        ,0x3e,0x41,0x41,0x41,0x22,0x00  //C 12
                        ,0x7f,0x41,0x41,0x41,0x3e,0x00  //D 18
                        ,0x7f,0x49,0x49,0x49,0x41,0x00  //E 24
                        ,0x7f,0x48,0x48,0x48,0x40,0x00  //F 30
                        ,0x3E,0x41,0x49,0x49,0x2E,0x00  //G 36
                        ,0x7F,0x08,0x08,0x08,0x7F,0x00  //H 42
                        ,0x41,0x7F,0x41,0x00,0x00,0x00  //I 48
                        ,0x11,0x5F,0x11,0x00,0x00,0x00  //İ 54
                        ,0x02,0x01,0x41,0x7e,0x40,0x00  //J 60
                        ,0x7f,0x08,0x14,0x22,0x41,0x00  //K 66
                        ,0x7f,0x01,0x01,0x01,0x01,0x00  //L 72
                        ,0x7f,0x20,0x18,0x20,0x7F,0x00  //M 78
                        ,0x7F,0x10,0x08,0x04,0x7F,0x00  //N 84
                        ,0x3E,0x41,0x41,0x41,0x3E,0x00  //O 90
                        ,0x7f,0x48,0x48,0x48,0x30,0x00  //P 96
                        ,0x3e,0x41,0x45,0x42,0x3d,0x00  //Q 102
                        ,0x7f,0x48,0x4C,0x4a,0x31,0x00  //R 108
                        ,0x32,0x49,0x49,0x49,0x26,0x00  //S 114
                        ,0x40,0x40,0x7F,0x40,0x40,0x00  //T 120
                        ,0x7E,0x01,0x01,0x01,0x7E,0x00  //U 126
                        ,0x1E,0x41,0x01,0x41,0x1E,0x00  //Ü 132
                        ,0x7C,0x02,0x01,0x02,0x7C,0x00  //V 138
                        ,0x7E,0x01,0x0E,0x01,0x7E,0x00  //W 144
                        ,0x63,0x14,0x08,0x14,0x63,0x00  //X 150
                        ,0x70,0x08,0x07,0x08,0x70,0x00  //Y 156
                        ,0x43,0x45,0x49,0x51,0x61,0x00  //Z 162
                        ,0x00,0x00,0x00,0x00,0x00,0x00  //Space 168
                        ,0x3E,0x45,0x49,0x51,0x3E,0x00  //0 174
                        ,0x21,0x7F,0x01,0x00            //1 178
                        ,0x21,0x43,0x45,0x49,0x31,0x00  //2  184
                        ,0x42,0x41,0x51,0x69,0x46,0x00  //3  190
                        ,0x0c,0x14,0x24,0x7f,0x04,0x00  //4  196
                        ,0x72,0x51,0x51,0x51,0x4e,0x00  //5  204
                        ,0x1e,0x29,0x49,0x49,0x06,0x00  //6  210
                        ,0x40,0x47,0x48,0x50,0x60,0x00  //7  216
                        ,0x36,0x49,0x49,0x49,0x36,0x00  //8  222
                        ,0x30,0x49,0x49,0x4a,0x3c,0x00  //9  228
                        ,0x1E,0x61,0x21,0x61,0x1E,0x00  //Ö  234
                        ,0x03,0x03,0x00                 //.  237
                        ,0x1B,0x1B,0x00                 //:  240
                        ,0x60,0x90,0x90,0x60,0x00       //'  245
                        ,0x09,0x09,0x09,0x09,0x09,0X00  //=  251
                        ,0x08,0x08,0x08,0x08,0X08,0x00  //-  257
                        ,0x00,0x03,0xFF,0xFF,0x03,0x00,0xFE,0xFF,0x03,0x03,0x02,0x00,0x00  //_ 270
                        ,0x00,0x10,0x3F,0xFF,0x00,0x00,0x3F,0xFF,0x60,0x60,0x20,0x00,0x00  //+ 283
                        ,0x60,0x92,0x94,0x68,0x16,0x29  //% 289
                        ,0x49,0x06,0x00                 //% 292
                        ,0x11,0x0f,0x11,0x10,0x08,0x00  //r
                        ,0x08,0x08,0x08,0x2a,0x1c,0x08,0x00  //>
                        ,0x00,0x03,0xFF,0xFF,0X03,0x00,0xFE,0xFF,0x03,0x03,0x02,0x00,0x00  //_ 361
                        ,0x00,0x10,0x3F,0xFF,0x00,0x00,0x3F,0xFF,0x60,0x60,0x20,0x00,0x00  //+ 374
void data_sec()
   switch (data)
   case 'A':
   adres_sec=0 ; yinele=5 ; break ;
   case 'B':
   adres_sec=6 ; yinele=5 ; break;
   case 'C':
   adres_sec=12 ; yinele=5 ; break;
   case 'D':
   adres_sec=18 ; yinele=5 ; break;
   case 'E':
   adres_sec=24 ; yinele=5 ; break;
   case 'F':
   adres_sec=30 ; yinele=5 ; break;
   case 'G':
   adres_sec=36 ; yinele=5 ; break;
   case 'H':
   adres_sec=42 ; yinele=5 ; break;
   case 'I':
   adres_sec=48 ; yinele=5 ; break;
   case 'İ':
   adres_sec=54 ; yinele=5 ; break;
   case 'J':
   adres_sec=60 ; yinele=5 ; break;
   case 'K':
   adres_sec=66 ; yinele=5 ; break;
   case 'L':
   adres_sec=72 ; yinele=5 ; break;
   case 'M':
   adres_sec=78 ; yinele=5 ; break;
   case 'N':
   adres_sec=84 ; yinele=5 ; break;
   case 'O':
   adres_sec=90 ; yinele=5 ; break;
   case 'P':
   adres_sec=96 ; yinele=5 ; break;
   case 'Q':
   adres_sec=102 ; yinele=5 ; break;
   case 'R':
   adres_sec=108 ; yinele=5 ; break;
   case 'S':
   adres_sec=114 ; yinele=5 ; break;
   case 'T':
   adres_sec=120 ; yinele=5 ; break;
   case 'U':
   adres_sec=126 ; yinele=5 ; break;
   case 'Ü':
   adres_sec=132 ; yinele=5 ; break;
   case 'V':
   adres_sec=138 ; yinele=5 ; break;
   case 'W':
   adres_sec=144 ; yinele=5 ; break;
   case 'X':
   adres_sec=150 ; yinele=5 ; break;
   case 'Y':
   adres_sec=156 ; yinele=5 ; break;
   case 'Z':
   adres_sec=162 ; yinele=5 ; break;
   case ' ':
   adres_sec=168 ; yinele=5 ; break;
   case '0':
   adres_sec=174 ; yinele=5 ; break;
   case '1':
   adres_sec=180 ; yinele=3 ; break;
   case '2':
   adres_sec=184 ; yinele=5 ; break;
   case '3':
   adres_sec=190 ; yinele=5 ; break;
   case '4':
   adres_sec=196 ; yinele=5 ; break;
   case '5':
   adres_sec=202 ; yinele=5 ; break;
   case '6':
   adres_sec=208 ; yinele=5 ; break;
   case '9':
   adres_sec=226 ; yinele=5 ; break;
   case 'Ö':
   adres_sec=232 ; yinele=5 ; break;
   case '.':
   adres_sec=238 ; yinele=2 ; break;
   case ':':
   adres_sec=241 ; yinele=2 ; break;
   case '`':
   adres_sec=244 ; yinele=4 ; break;
   case '=':
   adres_sec=249 ; yinele=5 ; break;
   case '-':
   adres_sec=255 ; yinele=5 ; break;
   case '_':
   adres_sec=261 ; yinele=12 ; break;
   case '+':
   adres_sec=274 ; yinele=12 ; break;
   case '%':
   adres_sec=286 ; yinele=8 ; break;
   case 'r':
   adres_sec=295 ; yinele=5 ; break;
   case '>':
   adres_sec=301 ; yinele=6 ; break;
   case '*':
   adres_sec=308 ; yinele=12 ; break;
   case '/':
   adres_sec=321 ; yinele=12 ; break;
   default:
   adres_sec=164 ; yinele=5 ;
 void Animasyon_Sec()
   //volatile int buton2=0;
   if(input(PIN_E2) & buton2==0)
      degis++;
      buton2=1;
      if (degis>2)degis=1;
      if (degis<1)degis=2;
      output_high(PIN_E1);
      write_eeprom(1,degis);
      delay_ms(20);
      reset_cpu();
   if(!input(PIN_E2))
      buton2=0;
      output_low(PIN_E1);
/**************************SÜTUN BİLGİSİ**************************/
void sutun_reg(char str[],int16 b)       //sutun_reg() alt programı.
 unsigned int j=0,i=0;                   //
 unsigned int16 y=0,stn_index;           //
 for(i=0;i<strlen(str);i++)              //
   data=str[i];                          //
   data_sec();                           //
   for(j=0;j<=yinele;j++,adres_sec++,y++)//
      sutun_1[y]=karakter[adres_sec];    //
 for(stn_index=y;stn_index<b;stn_index++)//
    sutun_1[stn_index]=0;                //
 y=0;                                    //
void sutun_reg_2(char str[],int16 b)       //sutun_reg() alt programı.
 unsigned int p=0,w=0;                   //
 unsigned int16 u=0,stn_index1;          //
 for(w=0;w<strlen(str);w++)              //
   data=str[w];                          //
   data_sec();                           //
   for(p=0;p<=yinele;p++,adres_sec++,u++)//
      sutun_2[u]=karakter[adres_sec];    //
 for(stn_index1=u;stn_index1<b;stn_index1++)//
    sutun_2[stn_index1]=0;                //
 u=0;                                    //
/*************************goto data display***************************/
void ekran_yaz(int tekrar)
 int s=0,i=0,j=0;
 for(j=0;j<tekrar;j++)
  for(s=0;s<16;s++)
   for(i=0;i<96;i++)
     Animasyon_Sec();
     if(s<8)output_bit(ds1,bit_test(sutun_1[i],s));
     if(s>=8)output_bit(ds1,bit_test(sutun_2[i],s-7));
     output_high(clock);
     delay_us(1);
     output_low(clock);
    if(s<8) output_b(0x00);
    if(s>=8)output_d(0x00);
    output_high(latch);
    delay_us(1);
    output_low(latch);
    if(s<8) output_b(s+1);
    if(s>=8 & s<16) output_d(s-6);
/***************************scroll message**************************/
void efekt_1(int16 kay , int mod)
 int reg_0=0;
 int16 n=0,k=0;
 for(n=0;n<kay;n++)
   ekran_yaz(10);
   disable_interrupts(INT_RDA);
   switch (mod)
    case 0:
      reg_0=sutun_1[0];
      for(k=0;k<(kay-1);k++)
         sutun_1[k]=sutun_1[k+1];
      sutun_1[kay-1]=reg_0;
    case 1:
      sutun_1[kay-1]=0;
    default:
   enable_interrupts(INT_RDA);
void efekt_2(int16 kay , int mod)
 int reg_0=0;
 int16 z=0,l=0;
 for(z=0;z<kay;z++)
   Animasyon_Sec();
   ekran_yaz(1);
   switch (mod)
    case 0:
      reg_0=sutun_2[0];
      for(l=13;l<(kay-1);l++)
         sutun_2[l]=sutun_2[l+1];
      sutun_2[kay-1]=reg_0;
    case 1:
      sutun_2[kay-1]=0;
    default:
void efekt_3(int16 yuk , int mod)
 int reg_0=0;
 int16 a=0,y=0;
 for(a=0;a<yuk;a++)
   ekran_yaz(10);
   switch (mod)
    case 0:
      reg_0=satir_1[0];
      for(y=0;y<(yuk-1);y++)
         satir_1[y]=satir_1[y+1];
      satir_1[yuk-1]=reg_0;
    case 1:
      satir_1[yuk-1]=0;
    default:
/*            main PROGRAM                   */
  int i=0;
   /*_______________________PORT GİRİŞ-ÇIKIŞ İŞLEMLERİ___________________________*/
   set_tris_a(0x00) ; set_tris_b(0x00) ;//pin_c7(RX) giriş,giğer
   set_tris_d(0x00) ; set_tris_e(0x00) ;//pinler çıkış
   output_a(0x00)   ; output_b(0x00)   ;//bütün çıkışları
   output_d(0x00)   ; output_e(0x00)   ;//temizle
   setup_adc_ports(NO_ANALOGS);           //adc pinleri digital
   setup_adc(ADC_OFF);                    //adc kapalı
   setup_psp(PSP_DISABLED);               //psp kapalı
   setup_spi(SPI_SS_DISABLED);            //spı kapalı
   setup_wdt(WDT_OFF);                    //wdt kapalı
   setup_timer_0(RTCC_INTERNAL);          //timer0 dahili kaynak
   setup_timer_1(T1_DISABLED);            //timer1 kapalı
   setup_timer_2(T2_DISABLED,0,1);        //timer2 kapalı
   setup_timer_3(T3_DISABLED|T3_DIV_BY_1);//timer3 kapalı
   //enable_interrupts(INT_RDA);            //rs232 bilgi giriş kesmesi aktif
   //enable_interrupts(GLOBAL);             //tüm kesmelere izin ver
   for(t=0;t<100;t++){
      sutun_1[t]=0;
      sutun_2[t]=0;
   //rtc_init();
   degis=read_eeprom(1);
   //mesaj_1[] dizisine kopyala
   while(true)
   /*********EEPROM'DAN SATIR BİLGİLERİNİ OKUMA VE SUTUN REGISTER'INA YAZMA*******/
  // for(i=0;i<4;i++)             //dahili eepromdan 55 karakter oku
  // mesaj_1[i]=read_eeprom(i);
   // char string[10], string2[10];
       Animasyon_Sec();
       switch(degis)
        case 1:
                sutun_reg(mesaj_1,145);     break;
                sutun_reg_2(mesaj_2,1);
        case 2:
                sutun_reg(mesaj_3,145); break;
                sutun_reg_2(mesaj_4,1);
   /***************************MESAJ RUTİNİ***************************/
   // ekran_yaz(320);
   // efekt_1(300,1);
    efekt_2(145,1);
   // efekt_3(320,1);
electronic
