Reading and scaling a mv reading from ADC
orlandoG
PostPosted: Thu Jun 24, 2010 10:23 am     Reply with quote
Hello
I have a question. I am designing a battery charger and I want to read the voltage with the ADC on my pic. I am using a voltage divider to step down the voltage by 100 (meaning 12.65V would be .1265V) which I am going to use later for reading higher voltages, anyhow I got the adc outputting the right values but I cannot figure out how to detect a small voltage change. For instance if I read a voltage of 12.65 I get an ADC value of 25 (.1265*1023)/5) now if I want to read a voltage of 12.45 I still get an adc value of 25. Does anyone have a better way of doing this?
thanks
Douglas Kennedy
PostPosted: Thu Jun 24, 2010 11:07 am     Reply with quote
The adc will count 1 for every 5/1023 or say every approx 5 mv. You take 12.65v and effectively make it .1265v with your divider. Now a 5mv step gives 25 approx for .125 (25 x 5mv) so 24 is .120v and 26 is .130. So with the divided by 100 you are restricted to approx 0.5v precision. The only way to keep good precision with a resister divider is to set the the range to be measured to 5v. If 20v is your max then you want 5v to be 1023 so you need 15k and 5k for the resistors or another set that maintains the same ratio.
SherpaDoug
PostPosted: Thu Jun 24, 2010 6:48 pm     Reply with quote
It's that 100:1 divider that is killing you. It gives you a 500V range, but 0.5V resolution.
Do you REALLY need a 500V range?
