Problems with Pic24 and LED
frankcr
PostPosted: Tue Jun 29, 2010 11:26 pm     Reply with quote
I want to use the pic 24fj128GA006 and a LED but I can't do it.
Here is my code:
#include <24FJ128GA006.h> //MICROCONTROLADOR UTILIZADO
//#device adc=10 //ADC 10 Bits de presicion
//****************************** FUSES **********************
#FUSES ICSP1                    //ICD uses PGC1/PGD1 pins
#FUSES NOWINDIS                 //Watch Dog Timer in Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES FRC                      //Internal Fast RC Oscillator
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES NOPR                     //Pimary oscillaotr disabled
#use delay (clock=4000000)         //Fosc=4Mhz
#use fast_io(e)
///PROGRAMA
   set_tris_e(0x3FE);   //portb como salida(RB0,las demas desactivadas)
   do{
      output_low(PIN_E0);   //led off
      output_high(PIN_E0);   //led on
   }while(TRUE);         //bucle infinito
I don't know if the problem is in the fuses.
I use the internal oscillator.
