lst file miss labels
jj1984
PostPosted: Tue Jun 22, 2010 10:22 am     Reply with quote
Hi, I'm working with 18f46j11, v4.093, and the problem is that the time change form 23:59:59 to 20:0:0 and I´ve read rtc_write() doesn´t work properly.
my code:
#include <18F46J11.h>
#FUSES  NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH(>10mhz for PCD)
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES PRIMARY                  //Primary clock is system clock when scs=00
#FUSES NOWPCFG
#FUSES WPBEG
#FUSES WPDIS
#FUSES NoLPT1OSC                  //Timer1 configured for low-power operation
#FUSES T1DIG
#FUSES MSSPMSK7
#FUSES RTCOSC_T1
#FUSES DSWDTOSC_INT
#FUSES NOCPUDIV
#use delay(clock=12M)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,errors)
#use rtos(timer=0,minor_cycle=20ms)
time_t tDate_all;
#TASK(rate=1s,max=20ms) //,queue=5)
void flash_led()
   output_toggle(PIN_C5);
#TASK(rate=2s,max=20ms) //,queue=5)
void flash_led2()
   output_toggle(PIN_C4);
#TASK(rate=3s,max=20ms) //,queue=5)
void flash_led3()
   output_toggle(PIN_D3);//31771);
void print1_1()
  rtc_read(&tDate_all);
  printf("HOla: %2u/%2u/%2u ** %2u:%2u:%2u\n\r",tDate_all.tm_mday,tDate_all.tm_mon,tDate_all.tm_year,tDate_all.tm_hour,tDate_all.tm_min,tDate_all.tm_sec);
#int_RTC
void RTC_isr(void)
   output_toggle(PIN_D2);
main()
   time_t tWriteTime;
   time_t tAlarmTime;
   tWriteTime.tm_year = 10;
   tWriteTime.tm_mon  = 6;
   tWriteTime.tm_mday = 19;
   tWriteTime.tm_wday = 6;
   tWriteTime.tm_hour = 23;
   tWriteTime.tm_min  = 58;
   tWriteTime.tm_sec  = 0;
   tAlarmTime.tm_year = 9;
   tAlarmTime.tm_mon  = 11;
   tAlarmTime.tm_mday = 24;
   tAlarmTime.tm_wday = 2;
   tAlarmTime.tm_hour = 16;
   tAlarmTime.tm_min  = 0;
   tAlarmTime.tm_sec  = 5;
   setup_timer_1(T1_EXTERNAL|T1_DIV_BY_2|0X08);//0X08 enables timer1, it seems not to be considered  in setup_timer_1
   setup_rtc(RTC_ENABLE | RTC_OUTPUT_SECONDS, 0x00);
  // setup_rtc_alarm(RTC_ALARM_ENABLE,RTC_ALARM_SECOND, 0xff);
   rtc_write(&tWriteTime);
   //rtc_alarm_write(&tAlarmTime);
   //enable_interrupts(int_rtc);
   //enable_interrupts(global);
       rtos_run();
The lst file show the next code:
....................    rtc_write(&tWriteTime);
0336:  MOVLB  F
0338:  MOVLW  55
033A:  MOVWF  FA7
033C:  MOVLW  AA
033E:  MOVWF  FA7
0340:  BSF    x3F.5
0342:  BSF    x3F.0
0344:  BSF    x3F.1
0346:  CLRF   FEA
0348:  MOVLW  3F
034A:  MOVWF  FE9
034C:  MOVLW  04
034E:  MOVWF  01
0350:  MOVF   FEE,W
0352:  MOVLB  0
0354:  RCALL  0298
0356:  MOVWF  F98
0358:  MOVF   FEE,W
035A:  RCALL  0298
035C:  MOVWF  F99
035E:  DECFSZ 01,F
0360:  BRA    0364
0362:  BRA    0368
0364:  MOVLB  F
0366:  BRA    0350
0368:  MOVLB  F
036A:  BCF    x3F.5
and I'm trying to understand that code, just that the label 0298 is not in lst file Confused, the code around that label is:
.................... #int_RTC
.................... void RTC_isr(void)
....................    output_toggle(PIN_D2);
028E:  BCF    F95.2
0290:  BTG    F8C.2
0292:  BCF    FA4.0
0294:  GOTO   0058
.................... main()
02BA:  CLRF   FF8
02BC:  BCF    FD0.7
02BE:  BSF    08.7
02C0:  CLRF   FEA
02C2:  CLRF   FE9
02C4:  BCF    F7E.3
02C6:  MOVLW  4D
02C8:  MOVWF  FB0
02CA:  MOVLW  A6
02CC:  MOVWF  FAD
02CE:  MOVLW  90
02D0:  MOVWF  FAC
02D2:  MOVLW  FF
02D4:  MOVLB  F
02D6:  MOVWF  x48
02D8:  BCF    FC2.6
02DA:  BCF    FC2.7
02DC:  MOVWF  x49
02DE:  MOVLW  07
02E0:  MOVWF  FB4
02E2:  CLRF   18
....................    time_t tWriteTime;
I hope someone can help me with that. I appreciate it.
Thanks.
PostPosted: Tue Jun 22, 2010 11:15 am     Reply with quote
It could be that it's not showing the CCS library code. To have the .LST
file show that code, you need to comment out the #nolist statement in
the 18F46J11.h file, as shown below in bold:
//////// Standard Header file for the PIC18F46J11 device ////////////////
#device PIC18F46J11
// #nolist
Then re-compile and check the .LST file.
