Panos
| use shift right/left with flex_lcd driver |
Posted: Thu Jun 10, 2010 6:52 am |
I have this very simple program:
| Code: | #include <16F877.H>
#use delay(clock = 4000000)
#include "flex_lcd.c"
lcd_init(); // Always call this first.
lcd_putc("\fHello World");
I use the flex_lcd driver for the 16x2 lcd HD4478U to display the word "hello world" and i would like to make a clear question:
Can i use the command shift_right (address, bytes, value)
to shift the "hello word" or i have to do it with a for loop.
In other words does the flex_lcd driver supports the shift command? |
Posted: Thu Jun 10, 2010 11:45 am |
Here is a side scrolling demo that works with the Flex lcd driver:
#include <16F877.H>
void lcd_scroll_right(void)
lcd_send_byte(0, 0x1E);
void lcd_scroll_left(void)
lcd_send_byte(0, 0x18);
int8 i;
lcd_init();
lcd_putc("\f"); // Clear the LCD
// The 16x2 LCD memory is 40 characters wide, so fill it
// up with data for two screens. Each line below must
// contain 40 characters (excluding the newline).
lcd_putc("Hello to the Side scrolling \n");
lcd_putc("world. demo. ");
for(i = 0; i < 20; i++) // Scroll for 20 chars
lcd_scroll_left();
delay_ms(200); // This sets the scroll speed
delay_ms(2000); // Wait 2 seconds between scrolling
// each screen.
Panos
Posted: Thu Jun 17, 2010 5:34 am |
Thank you very much PCM!! It works perfect! Although with the "lcd_scroll_left" comand it scrolls right and with the "lcd_scroll_right" scrolls left!! But i changed the "lcd_send_byte(0, 0x1E);" and "lcd_send_byte(0, 0x18);" and now it's right!!
Thank you!  |
