problem with DS1307
mojsa2000
problem with DS1307
PostPosted: Tue Jun 15, 2010 10:06 am     Reply with quote
hi
I want to use a DS1307. I have a problem that I can't undersatnd it. I have loaded time and date in ds1307 and when I read the time and date the first value that is read is true and the other values are not true.
Please help me.
#include <16f877.h>
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
#bit ack_check=0x91.6
#bit ack_dt=0x91.5
#include <lcd.c>
#define use_lcd_portd true //set port D to use LCD
unsigned int8 sec,min,hour,day,date,month,year;
unsigned int8 sec_bcd,min_bcd,hour_bcd,day_bcd,date_bcd,month_bcd,year_bcd;
unsigned int8 high_nibble,low_nibble;
read_sec()
i2c_start();
i2c_write(0xd0);
if(ack_check==0)
i2c_write(0x00);//set the address
if(ack_check==0)
i2c_start();
i2c_write(0xd1);
if(ack_check==0)
sec=i2c_read();
i2c_stop();
high_nibble=(sec&0xf0)>>4;
low_nibble=sec&0x0f;
sec_bcd=high_nibble*10+low_nibble;
printf("\r\%u",sec_bcd);
printf(lcd_putc,"%u",sec_bcd);
return sec_bcd;
read_min()
i2c_start();
i2c_write(0xd0);
if(ack_check==0)
i2c_write(0x01);//set the address
if(ack_check==0)
i2c_start();
i2c_write(0xd1);
if(ack_check==0)
min=i2c_read();
i2c_stop();
high_nibble=(min&0xf0)>>4;
low_nibble=(min&0x0f);
min_bcd=high_nibble*10+low_nibble;
printf("\r\%u",min_bcd);
printf(lcd_putc,"%u",min_bcd);
return min_bcd;
read_hour()
i2c_start();
i2c_write(0xd0);
if(ack_check==0)
i2c_write(0x02);//set the address
if(ack_check==0)
i2c_start();
i2c_write(0xd1);
if(ack_check==0)
hour=i2c_read();
i2c_stop();
high_nibble=(hour&0xf0)>>4;
low_nibble=hour&0x0f;
hour_bcd=high_nibble*10+low_nibble;
printf("\r\%u",hour_bcd);
return hour_bcd;
read_day_of_week()
i2c_start();
i2c_write(0xd0);
if(ack_check==0)
i2c_write(0x03);//set the address
if(ack_check==0)
i2c_start();
i2c_write(0xd1);
if(ack_check==0)
day=i2c_read();
i2c_stop();
high_nibble=(day&0xf0)>>4;
low_nibble=day&0x0f;
day_bcd=high_nibble*10+low_nibble;
printf("\r\%u",day_bcd);
return day_bcd;
lcd_init();
i2c_start();
i2c_write(0xd0);//write operation activates
if(ack_check==0)//check ack flag
if(ack_check==0)
i2c_write(0x45);//write second as 45
if(ack_check==0)
i2c_write(0x32);//write min as 32
if(ack_check==0)
i2c_write(0x18);//set hour as 18
if(ack_check==0)
i2c_write(0x01);
if(ack_check==0)
i2c_write(0x28);
if(ack_check==0)
i2c_write(0x08);
if(ack_check==0)
i2c_write(0x10);
if(ack_check==0)
i2c_stop();
read_sec();
read_min();
read_hour();
read_day_of_week();
P51D
Re: problem with DS1307
PostPosted: Tue Jun 15, 2010 10:46 am     Reply with quote
mojsa2000 wrote:
hi
which other values?
Did you realized that the values are in BCD code?
For year, minutes and seconds the lower nibble is for the values 0-9 and the higher nibble for 10,20,30...-90
I've wrote the code for an ATmega32 and the DS1307. This are the read and write functions with start and stop...
maybe it could help you
void write_ds1307(int address, int data){                        // write byte to DS1307
   i2c_start();
   i2c_write(RTC_Adresse|Write);
   i2c_write(address);
   i2c_write(data);
   i2c_stop();
int read_ds1307(int address){                                 // read byte of DS1307
   int data;
   i2c_start();
   i2c_write(address);
   i2c_start();
   i2c_write(RTC_Adresse|Read);
   data = i2c_read(NACK);
   i2c_stop();
   return(data);
void start_ds1307(){                                       //RTC starten
   int sec;
   if (ds1307_started) return;
   sec = (read_ds1307(0) & (~0x80));                            //CH = 0 -> start.
   write_ds1307(0,sec);
   ds1307_started = 1;
void stop_ds1307(){                                          //RTC stop
   int sec;
   sec = (read_ds1307(0) | 0x80);                            //CH = 1 -> stop.
   ds1307_started = 0;
best wishes
P51D
PostPosted: Tue Jun 15, 2010 11:05 am     Reply with quote
See this thread in the CCS code library for a ds1307 driver and a test
program. Use this driver instead of your code:
http://www.ccsinfo.com/forum/viewtopic.php?t=23255
Read all the posts in the thread for help with ds1307 problems.
