bootloader question
Douglas Kennedy
bootloader question
PostPosted: Wed Jun 09, 2010 3:44 pm     Reply with quote
I have a rs232 boot loader working in the form of the CCS examples ex_bootloader.c . This is a two step process.
1) using the programmer download the bootloader
2) using the bootloader download the application code
initially and at any other time a new version is needed.
Now I would like to try and modify things as follows
1) using the programmer download the bootloader and the application
2) at any other time a new version is needed download using the bootloader
The reason the fast speed of the programmer and the bootloader is expected to be used only as a contingency if a software patch is needed later.
Is the above possible?
PostPosted: Wed Jun 09, 2010 3:49 pm     Reply with quote
Read FvM's comments in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=38730
Douglas Kennedy
PostPosted: Wed Jun 09, 2010 7:49 pm     Reply with quote
Yes that was a great help
First I compiled the bootloader then
I was able to embed the bootloader in the application code
using
#import (file=xxxxx.hex,hex,range=xxxx:yyyy)
Then I compiled the first deliverable and using the programmer the PIC got the first deliverable ( bootloader plus application)
This is a nice solution
the first deliverable is compiled with the #import
and updates are compiled without it. If an update is needed the bootloader via rs232 can install it.
Thanks FvM and PCM_programmer
Glen
PostPosted: Sat Jun 12, 2010 1:09 pm     Reply with quote
I've done the same thing, but used a slightly different solution.
1) Download the bootloader with the programmer.
2) Download the application with the bootloader.
3) Upload the bootloader + application image with the programmer.
This gives you an image containing both the bootloader and the application that can be downloaded with the programmer. And the bootloader is in place if future updates to the application are needed.
Glen
PostPosted: Sun Jun 13, 2010 1:29 am     Reply with quote
The said method of reproducing the application image by copying it to a hex file works well, of course. I've applied it
in cases, where the CCS compiler missed to set some necessary configuration bits correctly (particularly for PIC24).
But it's a bit time consuming, and requires access to a target platform. Memory ranges must be selected manually for the
produced image, which is a possible source of faults. It's good, that CCS provides all means to assemble the factory
image by software tools only.
Frank
