LCD16x2 with 16f88
ngchien
LCD16x2 with 16f88
PostPosted: Fri Jun 11, 2010 12:32 am     Reply with quote
I want to use LCD16x2 with 16F88 but i can use driver.
I have a problem .
#include <stddef.h>
#define LCD_RS          PIN_D0
//#define LCD_RW          PIN_D3
#define LCD_EN          PIN_D1
#define LCD_D4          PIN_D4
#define LCD_D5          PIN_D5
#define LCD_D6          PIN_D6
#define LCD_D7          PIN_D7
// misc display defines-
#define Line_1          0x80
#define Line_2          0xC0
#define Clear_Scr       0x01
#separate void LCD_Init ();// ham khoi tao LCD
#separate void LCD_SetPosition ( unsigned int cX );//Thiet lap vi tri con tro
#separate void LCD_PutChar ( unsigned int cX );// Ham viet1kitu/1chuoi len LCD
#separate void LCD_PutCmd ( unsigned int cX) ;// Ham gui lenh len LCD
#separate void LCD_PulseEnable ( void );// Xung kich hoat
#separate void LCD_SetData ( unsigned int cX );// Dat du lieu len chan Data
// prototype statements
// D/n Cong
#use standard_io (C)
#use standard_io (D)
//khoi tao LCD**********************************************
    LCD_SetData ( 0x00 );
    delay_ms(200);       /* wait enough time after Vdd rise >> 15ms */
    output_low ( LCD_RS );// che do gui lenh
    LCD_SetData ( 0x03 );   /* init with specific nibbles to start 4-bit mode */
    LCD_PulseEnable();
    LCD_PulseEnable();
    LCD_PulseEnable();
    LCD_SetData ( 0x02 );   /* set 4-bit interface */
    LCD_PulseEnable();      /* send dual nibbles hereafter, MSN first */
    LCD_PutCmd ( 0x2C );    /* function set (all lines, 5x7 characters) */
    LCD_PutCmd ( 0x0C );    /* display ON, cursor off, no blink */
    LCD_PutCmd ( 0x06 );    /* entry mode set, increment & scroll left */
    LCD_PutCmd ( 0x01 );    /* clear display */
    // this subroutine works specifically for 4-bit Port A
    LCD_SetData ( swap ( cX ) | 0x08 );
    LCD_PulseEnable();
    LCD_SetData ( swap ( cX ) );
    LCD_PulseEnable();
    /* this subroutine works specifically for 4-bit Port A */
        output_high ( LCD_RS );
        LCD_PutCmd( cX );
#separate void LCD_PutCmd ( unsigned int cX )
    LCD_SetData ( swap ( cX ) );     /* send high nibble */
    LCD_PulseEnable();
    LCD_SetData ( swap ( cX ) );     /* send low nibble */
    LCD_PulseEnable();
    output_high ( LCD_EN );
    delay_us ( 3 );         // was 10
    output_low ( LCD_EN );
    delay_ms ( 3 );         // was 5
    output_bit ( LCD_D4, cX & 0x01 );
    output_bit ( LCD_D5, cX & 0x02 );
    output_bit ( LCD_D6, cX & 0x04 );
    output_bit ( LCD_D7, cX & 0x08 );
I want to use port B but i have warnning !!!
[img]http://i411.photobucket.com/albums/pp200/ngchien/ve%20mach/11111.jpg[/img]
PostPosted: Fri Jun 11, 2010 11:58 am     Reply with quote
Try using the Flex lcd driver. It has a better chance to work:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
