jony john
| HMC6352 Problem |
Posted: Tue Jun 08, 2010 3:02 am |
Hi all, I'm beginner in CCS.
When I download the program below and the result is nothing happen.
I was check the voltage at SDA and SCL pin and it's 4.88V although rotate the sensor.
I not sure the compass sensor is still ok or not. Can anybody help me to ensure the sensor is still work.
Code I have try:
#include <16F877A.H>
#use i2c(Master, sda=PIN_C4, scl=PIN_C3, FORCE_HW)
#define HMC6352_I2C_WRITE_ADDRESS 0x42
#define HMC6352_I2C_READ_ADDRESS 0x43
#define HMC6352_GET_DATA_COMMAND 0x41
// Read the compass heading. This is in units
// of 1/10's of a degree, from 0 to 3599.
int16 HMC6352_read_heading(void)
int8 lsb;
int8 msb;
i2c_start();
i2c_write(HMC6352_I2C_WRITE_ADDRESS);
i2c_write(HMC6352_GET_DATA_COMMAND);
i2c_stop();
delay_ms(7); // Allow 1 ms extra for safety
i2c_start();
i2c_write(HMC6352_I2C_READ_ADDRESS);
msb = i2c_read();
lsb = i2c_read(0);
i2c_stop();
return((int16)msb | ((int16)lsb << 8));
int16 heading;
heading = HMC6352_read_heading();
printf("Heading in degrees = %lu\n\r", heading/10);
mkuang
Posted: Tue Jun 08, 2010 7:15 am |
This:
should be this:
return((int16)lsb | ((int16)msb << 8));
You want to multiply the msb by 256 and add it to the lsb, not the other way around. |
jony john
| HMC6352 Problem |
Posted: Tue Jun 08, 2010 7:57 pm |
I have try follow your suggestion,but still the same result: nothing happen..
i don't know the sensor still ok or not bcause while solder 4 pin on the sensor the temperature is about 250-300 Celsius..how to know the sensor is good function.. |
zeronix
Posted: Tue Jun 08, 2010 8:22 pm |
| Have you configured the control register? The sensor have who_i_am register? He should send you a fixed result from this last register. |
jony john
| control register? |
Posted: Wed Jun 09, 2010 1:06 am |
| zeronix : What you talk about, I don't understand what you try to say. Can you explain detail.. |
