rs232 communication between two pic microcontroller
blackdragon
PostPosted: Wed Jun 02, 2010 5:27 am     Reply with quote
Hi folks,
I want to make rf temperature with using rs232 communication. I've already tried some code pieces but I didn't succeed. Any idea or help would be more than welcome.
Btw, microcontroller model isn't important for me.
::::::::::::::::::::::::: Transceiver :::::::::::::::::::::::::::::::
// mikrodenetleyici baþlýk dosyasý
#include <18F4550.h>
// gerekli register ayarlarý
#FUSES   NOPROTECT, NOPUT, NOWDT, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NOMCLR, XT
// 10bitlik analog çýkýþ
#device  ADC=10
// saat çarpan hýzý 4mHZ
#use     delay(clock=4000000)
// Seri iletiþim(USART) için gerekli ayarlar. Bu bildirim ile seri çýkýþ birimi seri porta
// yönlendirilmiþtir.
// Bant hýzý 9.6kbps, verici pini C6, alýcý pini C7, pariti biti yok, 8bitlik iletiþim
#use     rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8)
// B portunu LCD için tahsis et
#define USE_PORTB_LCD TRUE
#include <lcd.c>
#include "ds18b20.c"
#include "mpx4115.c"
#define T_BUFFER_SIZE 64
byte t_buffer[T_BUFFER_SIZE];
byte t_next_in = 0;
byte t_next_out = 0;
#int_tbe
void serial_isr() {
   if(t_next_in!=t_next_out)
      putc(t_buffer[t_next_out]);
      t_next_out=(t_next_out+1) % T_BUFFER_SIZE;
      disable_interrupts(int_tbe);
void bputc(char c) {
   short restart;
   int ni;
   restart=t_next_in==t_next_out;
   t_buffer[t_next_in]=c;
   ni=(t_next_in+1) % T_BUFFER_SIZE;
   while(ni==t_next_out);
   t_next_in=ni;
   if(restart)
      enable_interrupts(int_tbe);
   float temperature, pressure;        // global deðiþkenlerin tanýmlanmasý
   setup_adc_ports(AN0);            // PortA'nýn 0.pinini analog olarak ayarla
   setup_adc(ADC_CLOCK_DIV_4);      //
   set_adc_channel(0);
   do
      temperature = ds1820_read();  // ýsý deðerini sensörden oku
      pressure = mpx4115a_read();   // basýnç deðerini sensörden oku
      delay_ms(2000);
      printf(bputc,"%3.1fC\r\n",temperature);
   while (TRUE)
::::::::::::::::::::::::: Receiver ::::::::::::::::::::::::::::
#device  ADC=10
#include <lcd.c>
//char  const msg_default[] = "Booting..";
//char str[20];
//char tmpStr[20];
//long strSize;
//int i;
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
   int t;
   buffer[next_in]=getc();
   t=next_in;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
   lcd_init(); //lcd'yi çalýþtýr
   printf(lcd_putc,"STARTING"); //lcd ekrana yazý yazdýr
   printf(lcd_putc,"\f2010 SUMMER"); // lcd ekrana yazý yazdýr
   lcd_gotoxy(1,1); // birinci satýr
   printf(lcd_putc,"\f*************");   // lcd ekrana yazý yazdýr
   lcd_gotoxy(2,1);  //ikinci satýr
   printf(lcd_putc,"\n**************");
   enable_interrupts(INT_RDA);
   enable_interrupts(global);
    do {
      printf("\r\nBuffered data => ");
      while(bkbhit)
        putc( bgetc() );
   } while (TRUE);
PostPosted: Wed Jun 02, 2010 11:25 am     Reply with quote
Explain the serial port connections. Is one PIC connected to a PC,
at least for the transmitting ? Explain or post a diagram of the
Also, add the ERRORS parameter to the #use rs232() statement in
both programs. This will prevent a lockup of the UART receiver if one
PIC is receiving characters, but the code is not ready to accept them.
blackdragon
PostPosted: Wed Jun 02, 2010 3:37 pm     Reply with quote
Hi PCM programmer,
I have two pic for communication each other. One of them receiver, other one transceiver. You can see my connection as below;
U1 is a transceiver pic, it captures two information from temp and pressure sensor and sends to RCV receiver pic via rs232 but I have some issue with communication and sources.
Thanks for your help.
PostPosted: Wed Jun 02, 2010 4:57 pm     Reply with quote
Explain your problem in detail. Tell the result that you want to get,
and tell the result that you are getting now.
blackdragon
PostPosted: Thu Jun 03, 2010 6:25 am     Reply with quote
Hi again,
Actually I want to send couple of data (temperature and pressure) one pic microcontroller to other one with using rs232. I used code as above but I only see nothing.
I've seen lcd put messages, I think my rs232 communication doesnt work well. So if anyone give me any indication I would be more than welcome.
jbmiller
PostPosted: Thu Jun 03, 2010 7:27 am     Reply with quote
I'd add proper RS232 level translators(MAX232,etc.) to each PIC.
At least that way you could transmit data to a PC running a 'terminal' program to verify that PIC is running right.
Then you can send data from the PC to the 2nd PIC to verify that PIC is running right.
One step at a time,best to get each PIC running on it's own.
