spilz
Nokia 3310 display : how to draw circle and line ? |
Posted: Sun Aug 25, 2013 11:51 pm |
Hello everybody !!
I need your help for a project
I m using a Nokia 3310 display with a pic18f2550, everything is doing well, I'm able to write ASCII characters with the code I found in this forum, thanks for that.
But now I would like something more graphic for an analogic clock or an analogic compass, so something with circle and line
I found a topic here where the screens look very nice, but I have absolutely no idea how to write a code to draw something like this :(
Picture 1
Picture 2
Thanks for your help
Spilz |
Posted: Mon Aug 26, 2013 12:12 am |
Do a search, for "'Bresenham's algorithm".
Programmer, who designed a very efficient algorithm for drawing lines. His name has also been applied to a similar algorithm for drawing conic sections (which includes the circle), so a Google search should find both.
Key is that these involve operations that can efficiently be done even on simple processors.
spilz
Posted: Mon Aug 26, 2013 12:23 am |
Thanks for your reply, it s a good point to start
I will looking his algos
But the problem with the Nokia 3310 display is that we can not change 1 pixel, we have to change 8pixels hitch time :(
More difficult to draw a line in a circle :'( |
Posted: Mon Aug 26, 2013 2:02 am |
You have to do what everyone else does, and generate your own algorithm to allow you to set one pixel....
You need a copy of the devices memory in RAM, then you perform the operations you want to this, and write the data to the display.
Sorry, but that's the 'way it is'.
