#fuses WDT32768//WDT128 //Watch Dog Timer uses 1:128 Postscale
#fuses INTRC_IO //IO
#fuses NOPROTECT //Code not protected from reading
#fuses NOIESO //Oscillator switching is disabled, main oscillator is source
#fuses BROWNOUT //Reset when brownout detected
//#FUSES BORV21 //Brownout reset at 2.0V
#fuses PUT //Power Up Timer
#fuses STVREN //Stack full/underflow will cause reset
#fuses NODEBUG //Debug mode for use with ICD
#fuses NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#fuses NOWRT //Program memory not write protected
#fuses NOWRTD //Data EEPROM not write protected
#fuses NOWRTB //Boot block not write protected
#fuses NOWRTC //configuration not registers write protected
#fuses NOCPD //No EE protection
#fuses NOCPB //No Boot Block code protection
#fuses NOEBTR //Memory not protected from table reads
#fuses NOEBTRB //Boot block not protected from table reads
Can anyone help me on this?
bkamen
Joined: 07 Jan 2004 Posts: 1615 Location: Central Illinois, USA
Posted: Wed Jun 02, 2010 11:04 am
looks like you have them connected together maybe?
-Ben _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D
Posted: Wed Jun 02, 2010 11:19 am
Post a description of the external circuits connected to these two pins.
