mahalingam
Help me with compiler errors |
Posted: Sat Jul 17, 2010 11:38 pm |
Can anybody please help me to solve errors or correct my coding?
#include <18F14K50.h>
#fuses INTRC,NOWDT,NOPROTECT,NOLVP // use Internal osc
#use delay(clock=16000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
int Buffer,Buff=0,b;
#int_rda //enable usart receive interrupt
rs232_handler() //interrupt driven data read and store
b=getch(); //load character
Buffer[Buff+1]=b; //store character [Error line 32]
Buff++; //increment pointer
main()
enable_interrupts(INT_RDA);
do { while(True); }
[Error line 41]
Errors:
Quote: |
*** Error 66 Line 32(13,14): Previous identifier must be a pointer
*** Error 75 Line 41(1,2): Expect WHILE rs232_handler
Please help me as soon as possible friends.
Thank you. |
Posted: Sun Jul 18, 2010 12:54 am |
Look at the Ex_Sisr.c example to see how to declare an array
for use as a buffer in the #int_rda routine. Here is the file location:
Quote: |
c:\program files\picc\examples\ex_sisr.c
Quote: | *** Error 75 Line 41(1,2): Expect WHILE rs232_handler
Read a tutorial on how to correctly make a do-while statement:
http://blog.robbychen.com/2010/07/13/c-do-while-loop/
You need to learn C. This forum is not a C learning forum.
In other words, we don't want to teach you C. You need to
learn it outside of the forum. We'll help you with using CCS C
to write your programs, but it's your responsibilty to learn basic C. |
