I'm using PCH 3.249 with the PIC 18F4620 and I would like to be able to use an instruction that would cause a reset just like hardware /MCLR reset. Is there such a thing?
Thanks in advance, I've learned a lot from this forum.
Posted: Tue Jun 15, 2010 8:33 pm
Here's how to answer this question:
Search for a Reset instruction in this section of the PIC data sheet:
I had to download a new acrobat reader, then quickly found the "reset_cpu()" instruction in the ccs manual. It works like a charm. Thanks PCM programmer!
