RS485 Echo problem
bozzo
RS485 Echo problem
PostPosted: Wed Jan 28, 2009 9:10 am     Reply with quote
Hi everyone,
I have to PIC communicating over RS485 everything was fine
between 18F2620 and 16F628 with SN75176
But i had to change one of the PIC so i changed 16F628 to 16F690
but now i am getting on 16F690 the same data which i am sending.
what can i do any suggestions.
bozzo
PostPosted: Wed Jan 28, 2009 9:18 am     Reply with quote
i tried with ADM1485 it is working fine
but how can i solve it with other rs485 chips.
Thanks.
n-squared
PostPosted: Thu Jan 29, 2009 8:39 am     Reply with quote
The question that comes to mind is why you did NOT get an echo for the previous devices. RS-485 always returns transmitted data to receiver, unless you disable RX.
Could you post your code and schematic diagram?
Every solution has a problem.
bozzo
PostPosted: Thu Jan 29, 2009 8:56 am     Reply with quote
I searched this problem a little while.
First thing i found was that the voltage levels could be different;
voltage levels from different pins or device can be different (CMOS TTL ST etc.)
And on first device when i was disabling RX the time for disabling was enough but it wasn't enough for other device.
So in conclusion the code was almost the same i just changed the time between disabling TX and enabling RX.
Thanks.
