18F46J50 SPI2 Hardware Interface
Wayne_
PostPosted: Mon May 24, 2010 6:51 am     Reply with quote
Hi All,
I have just submitted a bug report to CCS and thought I would post it here to A, see if anyone else has encountered the problem (verify it Smile) and B, to let you know there is potentially a problem. I am still waiting for a response from CCS.
PCWH Compiler
Version 4.107
When using SPI2 of the 18F46J50 I have found that no matter what I configure in setup_spi2 it will always set CKE of SSP2STAT. setup_spi works fine for SPI1.
I have also issued a ticket to Microchip with regards to this device and the functionality of SPI2. Certain settings do not seem to be working properly.
There is quite a lot to explain but basically it appears that in certain modes the device (an SD card) responds with correct data (0x01) but I read the value I sent 0xFF, it is as though the SR is not being transfered to the buffer!
If I bit bang it I get the correct value back all though I ran in to another problem when switching between SSP hardware to send and IO to receive, There is a glitch on the CLK which causes the device to start transmission which means the response is 1 bit out.
In other modes I get 1 in 5 correct response.
I am monitoring the spi2 lines on a Logic Analyser
Also the SMP bit appears to be affecting transmission of data and not just reception, changing it alters what the card sends back (physically as seen on the scope) indicating it did not get the correct command.
As I said, this is more for info but if anyone has encountered similar problems then please post.
Lastly but not least, I have also discovered that you need a License to be able to produce hardware which uses the SD specification, this also includes using the SPI bus of an SD card. It will cost at least $1000 which gets you the Full SD specification and a further $3000 a year to keep the Licenses current.
