reading bin file from MMC card using pic16f876
lgeorge123
PostPosted: Sat May 22, 2010 6:26 am     Reply with quote
Hi everybody, I have a bitmap stored in bin file and saved in mmc to be read by pic16f876 and display in graphic lcd. Can someone give me suggestions or any other links how can I decode this bin file ??? Thanks !!!
MikeP
PostPosted: Sat May 22, 2010 3:14 pm     Reply with quote
How did you make this bin file?
If I were you I would make a PC program to decode and write out the file as 8bit values ready to be sent to glcd_ functions. I wrote a perl program to do something like this it could be changed to write out a file on the PC that could be read by the MMC/FAT driver function fatgetc().
http://www.ccsinfo.com/forum/viewtopic.php?t=40834&start=15
The problem with my perl code is it assumes a lot about the format of the bitmap 256x128 1 BitsPerPixel.
Will post if you think it will be helpful.
Do you have the CCS MMC/FAT code working?
