structures in CCS
assaad
structures in CCS
PostPosted: Tue May 18, 2010 2:55 am     Reply with quote
Hi all
I am new to ccs and trying to learn it ,
I have wote this code to learn how structures work
struct motor  {
CHAR name[10];
CHAR type[10];
INT  speed[7];
UNSIGNED CHAR location[15];
struct motor dc_motor1;
dc_motor1.name="drase";
dc_motor1.type="bmotor";
dc_motor1.speed=3800;
dc_motor1.location="sweden";
But when I compile it it gives me an error:
Expecting LVALUE such as a variable name or * expression
Could you help please to solve it ?
Thank you
collink
Re: structures in CCS
PostPosted: Tue May 18, 2010 11:13 am     Reply with quote
Which chip are you using and which compiler?
If I copy your code into a file on my end and pretend you were using a PIC18F2685 with compiler version 4.105 it has no errors.
Wayne_
PostPosted: Wed May 19, 2010 2:06 am     Reply with quote
The ability to copy a string into a char array using =
has only recently been introduced into the CCS compiler. It is not C compliant.
To do it in C you would use strcpy, sprintf, memcpy or some other method where you loop through the array :-
strcpy(dc_motor1.name, "drase");
I am not sure if this is your problem though as we don't know what version of compiler you are using.
smanzer
PostPosted: Sun May 23, 2010 8:59 pm     Reply with quote
Hi assaad,
The version number of any compiler has little to do with your question. Google struct and you will see lots of info like linked lists etc.
strcpy(dc_motor1.name,"drase");
// Should work fine...depending on how
// you define the struct, you may need:
strcpy(dc_motor1->name, "drase");
Keep at it, C is good, PIC's are great, and together they are amazing.
Steven
"I am always doing that which I can not do, in order that I may learn how to do it."
- Pablo Picasso
Wayne_
PostPosted: Mon May 24, 2010 2:15 am     Reply with quote
smanzer wrote:
Hi assaad,
Steven
If he is using the latest version of the compiler then :-
Should work and the problem lies elsewhere.
