Why to use low speed CAN if high speed CAN is available?
Posted: Tue May 18, 2010 8:39 am
Hello All,
My question is Why to use low speed CAN if high speed CAN is available.
Is there any hardware dependency on this.
Thank's
Sudhansu
collink
Re: Why to use low speed CAN if high speed CAN is available?
Posted: Tue May 18, 2010 11:08 am
sudhansu.s.das wrote:
Hello All,
Thank's
Sudhansu
The usual reason is because of noise. The slower the speed the more environmental noise you can tolerate, the longer distance you can go, etc, etc. Basically the faster you try to go the more critical the wiring setup is. Past a certain point you will no longer be able to keep up and errors will overtake valid data.
