PIC 16f877A LCD problem!
uaf5000
PostPosted: Tue May 18, 2010 3:31 pm     Reply with quote
Hello Guys,
I have interfaced LCD with my PIC 16f877a. I want to initially display words on my lcd but the problem is only garbage value is being displayed. Please tell me the solution. I have given the code to which i used to code the MCU (used microcode studio for coding).
Regards.
DEFINE LCD_RSREG PORTE
DEFINE LCD_RSBIT 0
DEFINE LCD_EREG PORTE
DEFINE LCD_EBIT 1
DEFINE LCD_RWREG PORTE
DEFINE LCD_RWBIT 2
DEFINE LCD_BITS 8
DEFINE LCD_LINES 2
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
PAUSE 500
TRISD = %00000000
TRISE = %00000000
ADCON1=%00000111
LOOP:
LCDOUT $FE, 1
PAUSE 250
LCDOUT "Good"
LCDOUT $FE, $C0
LCDOUT "Luck"
PAUSE 250
GOTO LOOP
END
PostPosted: Tue May 18, 2010 3:58 pm     Reply with quote
You're using PicBasic. This is a C forum. You're in the wrong forum for
your language. Here is the correct forum:
http://www.picbasic.co.uk/forum/forum.php
uaf5000
PostPosted: Wed May 19, 2010 1:09 pm     Reply with quote
So many thanks =)
