PIF16F874 SPI with C
davidshang
PostPosted: Fri Apr 30, 2010 3:12 pm     Reply with quote
I am new user with PIC.
Does anyone can show me how to send data to SPI port. (PIF16F874A with C)?
I want to send codes through SPI port (SDO) in sequence.
for example:
1st code: 0xdb,
2nd code: 0x06,
3rd code: 0xbf
all the source I can find online are in assembly language,
Thank you very much.
PostPosted: Fri Apr 30, 2010 3:59 pm     Reply with quote
If that is truly all you want to do, then this program will do it.
If you really want to create driver for an SPI peripheral chip, then
you need to post the manufacturer and part number of the chip.
#include <16F874A.H>
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_4);
spi_write(0xDB);
spi_write(0x06);
spi_write(0xBF);
davidshang
thanks
PostPosted: Sun May 02, 2010 12:54 pm     Reply with quote
Thanks.
I will try next week.
davidshang
not working
PostPosted: Wed May 05, 2010 10:46 am     Reply with quote
Above code seems not working.
The code below is copied from text book, but still no data out from SDO (RC5).
#include "16F874A.h"
#use spi(DI=PIN_C4, DO=PIN_C5, CLK=PIN_C3, ENABLE=PIN_A2, BITS=16)
   int Two=0xdb;
   setup_spi(spi_master);
      Two=spi_read();
      spi_write(Two);
Thanks.
Abdulla M.A.
View user's profile Send private message Visit poster's website Yahoo Messenger
PostPosted: Wed May 05, 2010 11:26 am     Reply with quote
int Two=0xdb;
// here you defined two=0xDB
        Two=spi_read();
            spi_write(Two);
here you have a mistake, in this statement
Two=spi_read();
you started read an input from a slave, which did not connect to MCU
so, the value of Two will be always zero, not 0xDB.
Abdulla
"A scientist can discover a new star, but he cannot make one. He would have to ask an engineer to do that."
"For an optimist the glass is half full, for a pessimist it's half empty, and for an engineer is twice bigger than necessary."
Try this simple program. You should see output on the SCK and SDO pins.
If you don't see output, it probably means there is something wrong with
your hardware. (Assuming you are using hardware, and not Proteus).
#include <16F874A.h>
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
main(void)
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_16);
   spi_write(0x55);
   delay_us(100);
davidshang
SDO and SDI
PostPosted: Wed May 05, 2010 4:52 pm     Reply with quote
By theory, I can get a serial signal 0x55 from RC5/SDO pin, and clock on RC3/SCK pin.
Do I need to connect SDO (RC5) to SDI (RC4) to form a loop.
I modified and can not get serial signal from SDO.
#include "16F874A.H"
   spi_write(0xff);
   delay_ms(300);
Thanks.
PostPosted: Thu May 06, 2010 2:46 am     Reply with quote
By theory???
You are testing, right? So do you have a signal or not?
Are you testing with real hardware or in a simulator like Proteus?
Yes.
First of all you have to know that in the v4 compiler CCS introduced a new SPI software module. The new module has a lot of features but we suspect it to have a few bugs left in.
The new module is configured with the line '#use spi'. The old hardware SPI configuration is still present too, and is configured with setup_spi().
Only use one method. DON'T use both two lines in your program!!
I recommend you remove the '#use spi' line.
Always post your compiler version number.
davidshang
PIC Simulator
PostPosted: Tue May 11, 2010 4:18 pm     Reply with quote
I am using MPLAB IDE 5.20, CCS C Compiler 4.104, Oshonsoft PIC Simulator IDE 6.33, still not signal from SDO when run under PIC simulator.
What simulator do you run your .hex file?
Thanks.
PostPosted: Tue May 11, 2010 4:35 pm     Reply with quote
I use hardware: PicDem2-Plus board and an oscilloscope.
davidshang
a
PostPosted: Wed May 12, 2010 9:07 am     Reply with quote
To PCM Programmer:
Could you do me a favor, could you compile your code for me (use MPLAB IDE with CCS)
main(void)
   spi_write(0x55);
   delay_us(100);
I want to know is my MPLAB IDE / CCS or Oshonsoft PIC Simulator IDE problem.
davidshang@hotmail.com
PostPosted: Wed May 12, 2010 11:05 am     Reply with quote
I don't want to do that. I don't want to email things to other people.
I only want to participate in the forum.
davidshang
Thanks.
PostPosted: Wed May 12, 2010 1:04 pm     Reply with quote
Thanks.
