ThePraiodanish
| Problem with external interrupt on 16F876A |
Posted: Thu May 13, 2010 10:33 am |
I've got a problem concerning external interrupts.
I am using the code posted somewhere else in this forum for reading the scancodes from a ps/2 keyboard, this works by triggering an interrupt with the falling edge of the ps/2 clock signal.
The code works just fine, but if I add a delay_ms within my main loop (which does nothing but check whether there are characters in the output buffer and sends them with printf via RS232), the interrupt seems to be blocked.
Why is the delay not interrupted by the interrupt and the received char is sent when delay has finished?
Thanks,
Thomas
here my main.c:
#include "main.h"
//D0 - Clock
//D1 - Data
// Clock must be the interrupt pin
#define CLOCK PIN_B0
#define DATA PIN_B1
unsigned char bData[16];
unsigned char idx=0;
unsigned char tmp=0;
unsigned char readByte();
unsigned char processByte();
void printKey();
byte keyhit();
unsigned char translate(unsigned char scancode);
volatile byte shiftSet = 0;
volatile byte kbBuffer[16];
volatile byte kbPos = 0;
volatile byte kbSize = 0;
volatile byte capsSet = 0;
volatile byte extFlag = 0;
volatile byte relFlag = 0;
volatile byte key=0;
void sendByte(byte b)
// not used in my application
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
int i=0;
int32 cntr = 0;
unsigned char k=0;
printf("READY >");
set_tris_b(0b11111011);
input(CLOCK);
input(DATA);
printf("Ready!\n");
ext_int_edge(H_to_L);
enable_interrupts(INT_EXT);
printKey();
// doesn't work anymore if comment slashes in front of one of
// the following lines is removed
//for(i=0 ; i < 10000 ; i++);
//delay_ms(100);
void printKey()
unsigned char k = 0;
if (kbSize > 0)
disable_interrupts(GLOBAL);
k = kbBuffer[(kbPos - kbSize)&0x0F];
kbSize--;
printf ("%c", k);
#int_ext
void kbInterrupt()
//disable_interrupts(INT_EXT);
volatile byte k=0;
k = processByte();
if(k != 0)
kbBuffer[kbPos] = k;
kbPos = ++kbPos & 0x0F;
kbSize++;
//enable_interrupts(INT_EXT);
return;
int i=0, t=0;
idx=0;
tmp=0;
i=0;
goto dataread;
// while(INPUT(CLOCK) != 0); // Wait for a keypress
t=0;
while(INPUT(CLOCK) != 0 && t<255) // Wait for clock, time out if needed
delay_us(1);
t++;
for(i=0; i<11; i++)
t=0;
delay_us(1);
t++;
dataread:
bData[idx]=INPUT(DATA);
idx++;
if(idx==9)
for(idx=1; idx<9; idx++)
if(bData[idx]!=0)
tmp|=(1<<(idx-1));
return tmp;
idx=0;
tmp=0;
// while(INPUT(CLOCK) == 0);
t=0;
while(INPUT(CLOCK) == 0 && t<255) // Wait for clock, time out if needed
delay_us(1);
t++;
static const unsigned char scantableAZ[]={
0x1C, 0x32, 0x21, 0x23, 0x24, 0x2B, 0x34, 0x33, 0x43, 0x3B, 0x42, 0x4B, 0x3A, // A-Z
0x31, 0x44, 0x4D, 0x15, 0x2D, 0x1B, 0x2C, 0x3C, 0x2A, 0x1D, 0x22, 0x35, 0x1A};
// Normal numeric scancodes, starting with ',' .
static const unsigned char scantable09n[]=
0x41, 0x4E, 0x49, 0x4A, // , - . /
0x45, 0x16, 0x1E, 0x26, 0x25, 0x2E, 0x36, 0x3D, 0x3E, 0x46, //Digits 0-9
0x00, 0x4C, 0x00, 0x55 // 0 ; 0 =
// Shift scancodes, starting at '!'
static const unsigned char scantable09s[]=
0x16, 0x52, 0x26, 0x25, 0x2E, 0x3D, 0x00, 0x46, 0x45, 0x3E, 0x55
// Normal misc. scancode map. Scancode, ASCII value
static const unsigned char scanmapn[]=
{0x54, '[', 0x5B, ']', 0x0E, '`', 0x5D, '\\', 0x52, '\''};
// Shifted misc. scancode map. Scancode, ASCII value
static const unsigned char scanmaps[]=
{0x1E, '@', 0x36, '^', 0x4E, '_', 0x54, '{', 0x5B, '}', 0x5D, '|',
0x4C, ':', 0x41, '<', 0x49, '>', 0x4A, '?', 0x0E, '~'};
// Scancode map independent of Shift
static const unsigned char scanmapx[]=
{0x29, ' ', 0x5A, '\r', 0x0D, '\t', 0x76, 27, 0x66, 0x08};
// Extended scancode map
static const unsigned char scanmape[]=
0x71, 0x7F
int i=0;
disable_interrupts(global);
putc(scancode); //################################################################
clear_interrupt(INT_EXT);
enable_interrupts(global);
if(extFlag == 0)
for(i=0; i<10; i+=2)
if(scanmapx[i] == scancode)
return scanmapx[i+1];
for(i=0; i<26; i++)
if(scantableAZ[i] == scancode)
if(shiftSet ^ capsSet)
return i+65;
return i+65 + 32;
if(shiftSet)
for(i=0; i<11; i++)
if(scantable09s[i] == scancode)
return i+'!';
for(i=0; i<22; i+=2)
if(scanmaps[i] == scancode)
return scanmaps[i+1];
} else
for(i=0; i<18; i++)
if(scantable09n[i] == scancode)
return i+',';
if(scanmapn[i] == scancode)
return scanmapn[i+1];
} else // Extended keys
for(i=0; i<2; i+=2)
if(scanmape[i] == scancode)
return scanmape[i+1];
//return '?';
return 0x00;
unsigned char i, j;
i = readByte();
if(i == 0xF0) //A key is being released
relFlag = 1;
return 0;
if(i == 0xE0) // Extended key operation
extFlag = 1;
relFlag = 0; //0xE0 always first in sequence, OK to clear this
return 0;
if(relFlag == 0) // Pressing a key
if(extFlag == 0) // Non-extended key pressed
if(i == 0x12 || i == 0x59)
shiftSet = 1;
return 0;
if(i == 0x58)
sendByte(0xED);
if(capsSet == 0)
capsSet = 1;
sendByte(0x04);
} else
capsSet = 0;
sendByte(0x00);
return 0;
j = translate(i);
extFlag = 0;
return j;
if(relFlag == 1) //Releasing a key
relFlag = 0; //If a flag was set but not handled, we wouldn't have gotten here
extFlag = 0; //OK to clear this here
if(extFlag == 0) // Releasing a nonextended key
shiftSet = 0;
return 0;
// } else // Releasing an extended key
// return 0;
// return 0;
return 0;
and main.h:
#include <16F876A.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES PUT //Powe#FUSES NOPROTECT //Code not protected from reading
//#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
//#use delay(clock=11059200)
#use delay(clock=21855000)
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B3,bits=8)
