dezso
| SED1335 again. |
Posted: Sun May 09, 2010 10:49 am |
Please help me on this problem I'm having with this display.
I have recently seen a you-tube video of some sed1335 display demonstration.
I got my display driver to stop flicker completely, however the write speed is painfully slow, it takes to turn a 10x30 pixel area from white to black approximately 1/2 second, in this video the whole screen update in a fraction of my time. I have sent him a message but no response.
What could be the problem with my driver? I need a 2x/ second update on certain area of the display, like clock, and graph.
I have read the data-sheet many times, analyzed many driver written for AVR and PC-linux/Dos, I don't see them worrying about timing at all or reading the D6 status.
I'm using the original sed1335.c and a modified graphics.c.
Timing isn't a big deal in my project, the few minimum timing criteria is definitely met and the max are most don't care or not important.
At this time the LCD is connected to a Vero Bread Board with 10" single wires, this could have anything to do with the flicker ?
If some of you have some time to look in to the data-sheet and try to understand what I am doing wrong, that would be great.
I could send the individual my complete project file, once we figure out how to drive this LCD properly then we can upload it here for every one else... _________________ I'm could be wrong many time's, at least I know what I'm doing  |
Posted: Sun May 09, 2010 12:50 pm |
Post a test program that calls glcd_rect() in graphics.c. First call it with
color=ON, and then color=OFF. Do this in a while loop in main().
The complete test program can probably be done in 10 lines, including
the preprocessor statements (#include, #fuses, #use delay) and the
call to glcd_init(). You can do it in 10 lines. Don't post all the Wizard code.
Don't post the drivers. Just #include sed1335.c and graphics.c in the
program. Then run it and post the update speed that you see on the lcd.
Time it with a stopwatch. Also post your compiler version.
If you do this, then I can try to duplicate the problem. |
dezso
dezso
Posted: Sun May 09, 2010 10:41 pm |
I'll do that tomorrow.
Thanks _________________ I'm could be wrong many time's, at least I know what I'm doing  |
