Problem with external interrupt on 16F876A
ThePraiodanish
PostPosted: Thu May 13, 2010 10:33 am     Reply with quote
I've got a problem concerning external interrupts.
I am using the code posted somewhere else in this forum for reading the scancodes from a ps/2 keyboard, this works by triggering an interrupt with the falling edge of the ps/2 clock signal.
The code works just fine, but if I add a delay_ms within my main loop (which does nothing but check whether there are characters in the output buffer and sends them with printf via RS232), the interrupt seems to be blocked.
Why is the delay not interrupted by the interrupt and the received char is sent when delay has finished?
Thanks,
Thomas
here my main.c:
#include "main.h"
//D0 - Clock
//D1 - Data
// Clock must be the interrupt pin
#define CLOCK PIN_B0
#define DATA  PIN_B1
unsigned char bData[16];
unsigned char idx=0;
unsigned char tmp=0;
unsigned char readByte();
unsigned char processByte();
void printKey();
byte keyhit();
unsigned char translate(unsigned char scancode);
volatile byte shiftSet = 0;
volatile byte kbBuffer[16];
volatile byte kbPos = 0;
volatile byte kbSize = 0;
volatile byte capsSet = 0;
volatile byte extFlag = 0;
volatile byte relFlag = 0;
volatile byte key=0;
void sendByte(byte b)
// not used in my application
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
      int i=0;
     int32 cntr = 0;
    unsigned char k=0;
    printf("READY >");
    set_tris_b(0b11111011);
    input(CLOCK);
   input(DATA);
   printf("Ready!\n");
    ext_int_edge(H_to_L);
    enable_interrupts(INT_EXT);
    printKey();
       // doesn't work anymore if comment slashes in front of one of
       // the following lines is removed
   //for(i=0 ; i < 10000 ; i++);
   //delay_ms(100);
void printKey()
    unsigned char k = 0;
      if (kbSize > 0)
         disable_interrupts(GLOBAL);
         k = kbBuffer[(kbPos - kbSize)&0x0F];
          kbSize--;
          printf ("%c", k);
#int_ext
void kbInterrupt()
   //disable_interrupts(INT_EXT);
    volatile byte k=0;
    k = processByte();
    if(k != 0)
        kbBuffer[kbPos] = k;
        kbPos = ++kbPos & 0x0F;
        kbSize++;
   //enable_interrupts(INT_EXT);
    return;
    int i=0, t=0;
    idx=0;
    tmp=0;
    i=0;
    goto dataread;
   // while(INPUT(CLOCK) != 0);   // Wait for a keypress
            t=0;
       while(INPUT(CLOCK) != 0 && t<255)   // Wait for clock, time out if needed
           delay_us(1);
           t++;
    for(i=0; i<11; i++)
        t=0;
            delay_us(1);
            t++;
        dataread:
        bData[idx]=INPUT(DATA);
        idx++;
        if(idx==9)
            for(idx=1; idx<9; idx++)
                if(bData[idx]!=0)
                    tmp|=(1<<(idx-1));
            return tmp;
            idx=0;
            tmp=0;
     //   while(INPUT(CLOCK) == 0);
        t=0;
        while(INPUT(CLOCK) == 0 && t<255)   // Wait for clock, time out if needed
            delay_us(1);
            t++;
static const unsigned char scantableAZ[]={
0x1C, 0x32, 0x21, 0x23, 0x24, 0x2B, 0x34, 0x33, 0x43, 0x3B, 0x42, 0x4B, 0x3A, // A-Z
0x31, 0x44, 0x4D, 0x15, 0x2D, 0x1B, 0x2C, 0x3C, 0x2A, 0x1D, 0x22, 0x35, 0x1A};
// Normal numeric scancodes, starting with ',' .
static const unsigned char scantable09n[]=
0x41, 0x4E, 0x49, 0x4A, // , - . /
0x45, 0x16, 0x1E, 0x26, 0x25, 0x2E, 0x36, 0x3D, 0x3E, 0x46,     //Digits 0-9
0x00, 0x4C, 0x00, 0x55 // 0 ; 0 =
// Shift scancodes, starting at '!'
static const unsigned char scantable09s[]=
    0x16, 0x52, 0x26, 0x25, 0x2E, 0x3D, 0x00, 0x46, 0x45, 0x3E, 0x55
// Normal misc. scancode map. Scancode, ASCII value
static const unsigned char scanmapn[]=
{0x54, '[', 0x5B, ']', 0x0E, '`', 0x5D, '\\', 0x52, '\''};
// Shifted misc. scancode map. Scancode, ASCII value
static const unsigned char scanmaps[]=
{0x1E, '@', 0x36, '^', 0x4E, '_', 0x54, '{', 0x5B, '}', 0x5D, '|',
0x4C, ':', 0x41, '<', 0x49, '>', 0x4A, '?', 0x0E, '~'};
// Scancode map independent of Shift
static const unsigned char scanmapx[]=
{0x29, ' ', 0x5A, '\r', 0x0D, '\t', 0x76, 27, 0x66, 0x08};
// Extended scancode map
static const unsigned char scanmape[]=
0x71, 0x7F
    int i=0;
   disable_interrupts(global);
   putc(scancode); //################################################################
   clear_interrupt(INT_EXT);
   enable_interrupts(global);
    if(extFlag == 0)
        for(i=0; i<10; i+=2)
            if(scanmapx[i] == scancode)
                return scanmapx[i+1];
        for(i=0; i<26; i++)
            if(scantableAZ[i] == scancode)
                if(shiftSet ^ capsSet)
                    return i+65;
                    return i+65 + 32;
        if(shiftSet)
            for(i=0; i<11; i++)
                if(scantable09s[i] == scancode)
                    return i+'!';
            for(i=0; i<22; i+=2)
                if(scanmaps[i] == scancode)
                    return scanmaps[i+1];
        } else
            for(i=0; i<18; i++)
                if(scantable09n[i] == scancode)
                    return i+',';
                if(scanmapn[i] == scancode)
                    return scanmapn[i+1];
    } else      // Extended keys
        for(i=0; i<2; i+=2)
            if(scanmape[i] == scancode)
                return scanmape[i+1];
    //return '?';
   return 0x00;
    unsigned char i, j;
    i = readByte();
    if(i == 0xF0)       //A key is being released
        relFlag = 1;
        return 0;
    if(i == 0xE0)       // Extended key operation
        extFlag = 1;
        relFlag = 0;    //0xE0 always first in sequence, OK to clear this
        return 0;
    if(relFlag == 0)    // Pressing a key
        if(extFlag == 0)    // Non-extended key pressed
            if(i == 0x12 || i == 0x59)
                shiftSet = 1;
                return 0;
            if(i == 0x58)
                sendByte(0xED);
                if(capsSet == 0)
                    capsSet = 1;
                    sendByte(0x04);
                } else
                    capsSet = 0;
                    sendByte(0x00);
                return 0;
        j = translate(i);
        extFlag = 0;
        return j;
    if(relFlag == 1)    //Releasing a key
        relFlag = 0;    //If a flag was set but not handled, we wouldn't have gotten here
        extFlag = 0;    //OK to clear this here
        if(extFlag == 0)   // Releasing a nonextended key
                shiftSet = 0;
                return 0;
//        } else              // Releasing an extended key
//            return 0;
//        return 0;
    return 0;
and main.h:
#include <16F876A.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES PUT                      //Powe#FUSES NOPROTECT                //Code not protected from reading
//#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
//#use delay(clock=11059200)
#use delay(clock=21855000)
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B3,bits=8)
PostPosted: Thu May 13, 2010 11:40 am     Reply with quote
It's because you are using CCS delay routines in both your isr and your
main code. Only one instance of the delay routines has been invoked
by the #use delay() line. The delay routines are not re-entrant.
The compiler notices that you are doing this and disables interrupts
around the calls to the delay routines in your main code. This protects
against a crash caused by calling non-reentrant routines during an
interrupt. CCS will issue a warning about this during compilation, if
you have compiler warnings enabled.
One way to fix it would be to change the design of your program so you
don't call any delay routines while inside the isr (interrupt service
routine). Your interrupt routine is fairly long.
Another way is to add a 2nd instance of the CCS library code for the
delay routines. This post has an example:
http://www.ccsinfo.com/forum/viewtopic.php?t=27345&start=1
ThePraiodanish
PostPosted: Thu May 13, 2010 12:47 pm     Reply with quote
Thanks for your fast reply, I didn't even recognize that warning before Smile
Now it works as it should!
