eco_985
spi communication |
Posted: Mon May 03, 2010 1:53 pm |
I am communicating over SPI between two pics 16f877a. For some reason the data does not transfer correctly. I send the same byte out every 100ms. No matter what I sent. What can be wrong? Is it a software problem or can it be in the hardware problem?
transmitter code
#if defined(__PCM__)
#include <16F877A.h>
#device ADC=10
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#use delay(clock=40000000)
#use rs232(baud=19200,xmit=PIN_c6,rcv=PIN_c7)
//#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#org 0x1F00,0x1FFF {}
#opt 9
#include <LCD.C >
#define SPI_MODE_0 (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1 (SPI_L_TO_H)
#define SPI_MODE_2 (SPI_H_TO_L)
#define SPI_MODE_3 (SPI_H_TO_L | SPI_XMIT_L_TO_H)
#define SS_PIN PIN_C5 //data shhetten bakıldı
int8 val;
set_tris_d(0b00000000);
set_tris_c(0b10000000);
set_tris_b(0b00000000);
set_tris_a(0b00000000);
printf("maindeyim\n\r");
setup_adc_ports(AN0);
set_adc_channel(0);
setup_spi(SPI_MASTER | SPI_MODE_1 | SPI_CLK_DIV_64);
while(true) {
val = read_adc();
output_low(SS_PIN);
delay_us(10);
spi_write(val);
printf("%i gonderildi\n\r",val);
delay_ms(2000);
output_high(SS_PIN);
printf("high yapildi\n\r");
delay_ms(10);
reciever code
#device ADC=10
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
//#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#opt 9
#include <LCD.C >
unsigned int8 val;
setup_spi(SPI_SLAVE | SPI_MODE_1 );
//setup_spi(SPI_MASTER | SPI_MODE_1 | SPI_CLK_DIV_64);
printf("slave in mainideyim\n\r");
while(true) {
printf("while -slave\n\r");
val = spi_read();
printf("slave okuma yapildi\n\r %i",val);
lcd_gotoxy(1, 1);
printf(lcd_putc, "Pot at: %u ", val);
Posted: Mon May 03, 2010 1:59 pm |
The TRIS is wrong. You have set most pins to be outputs. A '0' means
the pin is an output, and yet you want to receive data on the SDI pin,
which must be set as an input.
With CCS, you don't actually have to set the TRIS. If you use CCS
functions and use Standard i/o mode, CCS will take care of it for you.
It will do it all correctly. You don't have to worry about it. Standard i/o
mode is the default mode. You don't have to specify it.
My advice is to delete all the #use fast_io lines, and delete all the
set_tris_x lines.
Also, look at this CCS example code. Notice how they call a function
to check if data has been received by the Slave, before they read it.
Quote: | c:\program files\picc\examples\ex_spi_slave.c |
eco_985
i did your advise but it doesn't work |
Posted: Mon May 03, 2010 2:54 pm |
PCM programmer wrote: | The TRIS is wrong. You have set most pins to be outputs. A '0' means
set_tris_x lines.
