UART and Errors
umka
UART and Errors
PostPosted: Fri Apr 30, 2010 2:56 am     Reply with quote
I am having a problem understanding the errors part of the #use RS232 function. I want to know if there was a problem during transmission so have set the timeout and errors but don't understand how to know if there was a timeout. If there was a problem I was to resend the data so need to know if there where any problems.
My code:
#use RS232(Uart1,Baud=9600,Timeout=10,Errors)
I think I read somewhere that Errors would be set to 0 if there had been a timeout so I tried this but it gives me an error.
 RS232_ERRORS == 0
PostPosted: Fri Apr 30, 2010 1:35 pm     Reply with quote
This test program compiles OK with no errors, with vs. 4.107:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, TIMEOUT=500, ERRORS)
int8 c;
int8 result;
c = getc();
if(RS232_ERRORS == 0)
   printf("Got Timeout Error \n\r");
umka
PostPosted: Sat May 01, 2010 12:48 am     Reply with quote
cheers PCM
got it working now. Had it in an or statement and that was the problem. having never used errors I guessed that was the problem.
Douglas Kennedy
PostPosted: Sat May 01, 2010 2:33 pm     Reply with quote
Errors doesn't end errors they are still there that's why it's called errors instead of error-free. All errors does is allow the uart to continue since your are effectively considered to have handled the error. Now in reality there isn't much you can do with the error since there is no good way to recover the data. The value is that the error is detected and the uart kept alive so a sophisticated program could ask for a retransmission. The value in the variable error is mostly the value in the uart register that informs of the specific error.
