dspic
balaji
dspic
PostPosted: Thu Apr 29, 2010 7:26 am     Reply with quote
Hai All,
I am using dsPIC30F3011 for my project. I use UART2 for communicating my PC.
#include <30F3011.h>
#use delay(clock = 4000000) // declaring osc frequency//
#FUSES HS                      //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES PR                       //Primary Oscillator
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES PUT64                    //Power On Reset Timer value 64ms
//#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOCOE                    //Device will reset into operational mode
#FUSES ICSP1                    //ICD uses PGC1/PGD1 pins
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#include <stdio.h>
#use rs232(UART2,baud = 4800)
#define  TRISB = 0x02C6
#define  TRISF = 0x02DE
     set_tris_b(0x0000);
     set_tris_f(0x0000);
   printf("hello");
   output_high(pin_B0);
    output_high(pin_F0);
   output_low(pin_B0);
   output_low(pin_F0);
The result is I'm always getting some repeated garbage value in Terminal window. I tried many baud rate in PC but still the result is same.
Pls help.
PostPosted: Thu Apr 29, 2010 8:46 am     Reply with quote
The obvious question is 'what is your oscillator frequency'. You have HS selected (which is for crystals > 10MHz), but the delay statement set to use 4MHz. Having this high gain mode selected, can result in the crystal locking onto the wrong frequency. Do a simple 'pulse a pin' test, operating it at (say) 1Hz, and see if the output is at the frequency you expect. This needs to be 'right', before trying serial I/O.
balaji
it works
PostPosted: Thu Apr 29, 2010 8:49 am     Reply with quote
Thank you sir for your reply.
I changed the MCLR comment and now it works.
I look guidance for Dual Uart. How to work on it.
pls help
