Goodwinchang
How to set the calibration value for PIC10F22x |
Posted: Thu Jul 26, 2007 9:18 pm |
as the tiltle. And another problem is for PIC10F222 the function setup_adc(ADC_ON). It will cause the Compiler error.
Please help.
Goodwin |
Posted: Fri Jul 27, 2007 1:49 pm |
What's your compiler version ?
The setup_adc(ADC_ON) function compiles OK with vs. 3.249.
With regard to the oscillator calibration, the 10F222 data sheet says:
Quote: | In addition, a calibration instruction is programmed into
the last address of memory, which contains the calibration
value for the internal oscillator. This location is
always uncode protected, regardless of the code-pro-tect
settings. This value is programmed as a MOVLW XX
instruction where XX is the calibration value and is
placed at the Reset vector. This will load the W register
with the calibration value upon Reset and the PC will
then roll over to the users program at address 0x000.
The user then has the option of writing the value to the
OSCCAL Register (05h) or ignoring it. |
CCS does this. At address 0x0000, it puts this line of code:
Register 05 is the OSCCAL register. It's putting the calbration value
(in the W register) into it. This is in the .LST file for vs. 3.249. |
spradecom.rnd
Posted: Wed Apr 28, 2010 3:16 am |
I am using version 4.84. what is the solution for the setup_adc(ADC_ON);
I have tried setup_adc(true); but the adc value always remains 255 or max even if input is zero |
Posted: Wed Apr 28, 2010 7:18 am |
Just add the define for ADC_ON.
For some reason these were missing from the V4 compilers up to somewhere around 4.09x.
#define ADC_ON (1)
Somewhere before you use the setup_adc function.
Seriously though, the values appearing, marked the point where CCS at long last got the compiler working with the chip. You will probably find it is not programming the pins properly as analog inputs, which is why it doesn't work with 'TRUE'....
spradecom.rnd
Posted: Wed Apr 28, 2010 8:45 am |
I have upgraded to version 4.104. The adc_on definition is present in the header. But after loading the program the adc value always remains high. MCLR pin always high, ICSPCLK pin always high. AN0 low. GP2 98%duty cycle. ADC val max. Here is the code. Generating sw PWM by reading analog inputs. This code works well with pic12f675
#include <10F222.h>
#device adc=8
#FUSES NOMCPU //Master Clear Pull-up disabled
#FUSES IOSC4 //INTOSC speed 4 MHz
#FUSES RESERVED //Used to set the reserved FUSE bits
setup_adc_ports(sAN0);
setup_adc(ADC_CLOCK_DIV_4);
// TODO: USER CODE!!
while(true)
set_adc_channel(0);
delay_ms(10);
value = Read_ADC();
//delay_ms(10);
output_high(PIN_B2);
delay_ms(value);
output_low(PIN_B2);
delay_ms(255-value);
Posted: Wed Apr 28, 2010 2:40 pm |
You comment 'MCLR is always high'. This says there is something wrong with your circuit, or the programming.
On this CCS version, the pull-up disable is correctly set when asked for (as shown), and except for this, the MCLR pin is an _input_ there is no circuitry except the pull-up, to take it high. If it is being pulled high, it implies that either your circuit is doing this, or that the programmer you are using, is not correctly setting the configuration bits. Either then could explain why the code doesn't work...
spradecom.rnd
Posted: Thu Apr 29, 2010 3:13 am |
I have checked setting. There is nothing I could figure out. I have checked the setting also. As soon as I power my board the chip goes in reset mode. MCLR high, ICSPCLK high, AN0 low but ADC value max, GP2 98% duty. Right now I have only connected PIC10f222 with programming pins rest all the connections I have removed. Here is the code.
Code: | CCS PCB C Compiler, Version 4.104, 5967 29-Apr-10 13:29
Filename: C:\Documents and Settings\Administrator\My Documents\new_io\new_io.lst
ROM used: 60 words (12%)
Largest free fragment is 452
RAM used: 5 (22%) at main() level
6 (26%) worst case
Stack: 1 locations
0000: MOVWF 05
0001: GOTO 015
0002: GOTO 003
.................... #include "C:\Documents and Settings\Administrator\My Documents\new_io\new_io.h"
.................... #include <10F222.h>
.................... //////// Standard Header file for the PIC10F222 device ////////////////
.................... #device PIC10F222
.................... #list
.................... #device adc=8
.................... #FUSES NOWDT //No Watch Dog Timer
.................... #FUSES NOMCLR //Master Clear pin used for I/O
.................... #FUSES NOPROTECT //Code not protected from reading
.................... #FUSES NOMCPU //Master Clear Pull-up disabled
.................... #FUSES IOSC4 //INTOSC speed 4 MHz
.................... #FUSES RESERVED //Used to set the reserved FUSE bits
.................... #use delay(clock=4000000)
0003: MOVF 0E,W
0004: BTFSC 03.2
0005: GOTO 014
0006: MOVLW 01
0007: MOVWF 0A
0008: CLRF 09
0009: DECFSZ 09,F
000A: GOTO 009
000B: DECFSZ 0A,F
000C: GOTO 008
000D: MOVLW 4A
000E: MOVWF 09
000F: DECFSZ 09,F
0010: GOTO 00F
0011: GOTO 012
0012: DECFSZ 0E,F
0013: GOTO 006
0014: RETLW 00
.................... int8 value;
.................... void main()
0015: CLRF 04
.................... setup_adc_ports(sAN0);
0018: BSF 07.6
0019: BCF 07.7
.................... setup_adc(ADC_ON);
001A: BSF 07.0
.................... setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
001B: MOVLW 08
001C: OPTION
.................... // TODO: USER CODE!!
.................... while(true)
.................... set_adc_channel(0);
001D: MOVLW 00
001E: MOVWF 0A
001F: MOVF 07,W
0020: ANDLW F3
0021: IORWF 0A,W
0022: MOVWF 07
.................... delay_ms(5);
0023: MOVLW 05
0024: MOVWF 0E
0025: CALL 003
.................... value = Read_ADC();
0026: BSF 07.1
0027: BTFSC 07.1
0028: GOTO 027
0029: MOVF 08,W
002A: MOVWF 0B
.................... output_high(PIN_B2);
002B: BCF 0C.2
002C: MOVF 0C,W
002D: TRIS 6
002E: BSF 06.2
.................... delay_ms(value);
002F: MOVF 0B,W
0030: MOVWF 0E
0031: CALL 003
.................... output_low(PIN_B2);
0032: BCF 0C.2
0033: MOVF 0C,W
0034: TRIS 6
0035: BCF 06.2
.................... delay_ms(255-value);
0036: MOVLW FF
0037: MOVWF 0D
0038: MOVF 0B,W
0039: SUBWF 0D,F
003A: MOVF 0D,W
003B: MOVWF 0E
003C: CALL 003
003D: GOTO 01D
003E: SLEEP
Configuration Fuses:
Word 1: 0FEA NOMCLR NOPROTECT NOWDT NOMCPU IOSC4 |
