balaji
| dsPIC dual UART |
Posted: Thu Apr 29, 2010 8:37 am |
Hai all,
I am using dsPIC30F3011 for my project. I need full duplex comm for both UART.
I tried with one UART. It`s working fine. Now if i enable both UART then how the data will send/receive from ports. I`m confused
can anybody help me.
Thanks in advance. |
Posted: Thu Apr 29, 2010 9:29 am |
First thing, streams.
You use stream names in the two #use RS232 declarations, and stream names to get/put the characters (fgetc, fputc, and fprintf, rather than getc/putc).
Second thing, if using interrupts, there are two interrupts for the two UARTs. Normally INT_RDA for the first, and INT_RDA2 for the second.
balaji
| u r right |
Posted: Fri Apr 30, 2010 3:37 am |
| It works with streams. |
