project2010
LCD display keep flashing |
Posted: Sun Apr 25, 2010 7:19 am |
Code: | #include <18F4620.H>
#device adc=10
#use delay(clock=2000000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#include <LCD20x4.c>
int16 adc_value;
float volts;
lcd_init();
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
adc_value = read_adc();
volts = (float)(adc_value * 500)/1023.0;
lcd_gotoxy(2,1);
printf(lcd_putc, "\f%3.2fv", volts);
printf(lcd_putc, "\f%3.2fC", volts);
if i replaced it by printf(lcd_putc, "%3.2fC", volts);
it will not keep flashing ,
but if the volt under 10 such as 9.56 it will display 9.56vv
it loop the \f.....
how can i solve it ? thank you
Humberto
Posted: Sun Apr 25, 2010 10:25 am |
The problem is that your input voltage is higher than the Vref.
Using:
setup_adc_ports(AN0); // The +5v is used as a Vref.
I gues that you are using a Vin/2 voltage divider.
When the input voltage is higher than 10.0V, let says 10.6V you get:
(10.6V*500)/1023= 5.18V
You need to recalculate the voltage divisor in the input AN0 in order that Vin
by no way should be higher that +5V.
Humberto
project2010
Posted: Sun Apr 25, 2010 10:44 am |
Humberto wrote: | The problem is that your input voltage is higher than the Vref.
Using:
Humberto |
oh...i just made and example....i have not focus on the voltage...
you're right, the v max must be=<5V
Anyway thank you for your reply. |
project2010
Posted: Sun Apr 25, 2010 10:45 am |
thank you PCM programmer:grin: , problem fixed.
This is the only way to fix it? add a if() |
project2010
Posted: Sun Apr 25, 2010 11:14 am |
i try it that's good.
i also found if i use %3.0f it can auto provide a space before the no.
_88 <like this |
