pulse width input
Aamir
pulse width input
PostPosted: Tue Apr 20, 2010 8:41 am     Reply with quote
I am using PIC12f675 to make a project such that it takes input pulses of 50Hz that is 20ms and analyze the duty cycle. After analysis I need an On time and Off time (which I will get from duty cycle) that I will use for my desired outputs.
Is there any method to do such thing? A code sample will be appreciated.
PostPosted: Tue Apr 20, 2010 3:46 pm     Reply with quote
The 12F675 doesn't have a CCP module, so if you want to measure
the pulse width, you need to do it in software. The following program
takes the ASM code from the PicBasic Pro PULSIN command and puts it
in a function "wrapper" so it can be used with CCS. This code can be
used to measure the pulse width of a signal on any PIC input pin.
The program below will work with your 50 Hz signal. Pulse widths
will vary from 0 to about 20 ms. The accuracy is within 4%.
This is the test program. It should be saved as "pulsin_test.c".
#include <16F877.H>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#include "pulsin.c"
int16 result;
int16 pulse_width_usec;
// Measure the pulse width of the signal on pin B0.
// The pulse width is displayed in microseconds.
   result = pulsin(PIN_B0, 1);
   pulse_width_usec = result * 10;
   printf("%lu\n\r", pulse_width_usec);
This is the Pulsin driver code. It should be saved as "pulsin.c".
#ifdef __PCB__
#error  Pulsin is not supported for the PCB compiler.
#ifdef __PCD__
#error  Pulsin is not supported for the PCD compiler.
#ifdef __PCM__
#define interrupt_enabled(x)  !!(*make8(x,1) & make8(x,0))
#ifdef __PCH__
#define interrupt_enabled(x)  !!(*(make8(x,1) | 0xF00) & make8(x,0))
#define BYTE_PTR(x) &(int8 *)(x)
// ASM definitions
#define W  0
#define F  1
// Status Register Bits
#define Z  2
#define C  0
#ifdef __PCM__
// Register addresses (16F)
#byte INDF   = 0x00
#byte STATUS = 0x03
#byte FSR    = 0x04
#ifdef __PCH__
// Register addresses (18F)
#byte INDF0  = 0xFEF
#byte STATUS = 0xFD8
#byte FSR0H  = 0xFEA
#byte FSR0L  = 0xFE9
// #define PULSIN_MAX  60000
#ifdef PULSIN_MAX
  #if(PULSIN_MAX > 65535)
      #error PULSIN MAX is too High. Maximum value is 65535.
#ifdef __PCM__
int16 pulsin(int8 ccs_pin, int8 state)
int8 io_port;
#ifdef __PCH__
int16 pulsin(int16 ccs_pin, int8 state)
int16 io_port;
int8 const bitmask_table[] = {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
int8 gie_enabled = FALSE;
int8 bitmask;
int8 flip;
int16 count;
// These variables are used in the ASM code
// and must be located in the same RAM bank.
#locate io_port = 0x30  // Can be 8 or 16 bits
#locate count   = 0x32  // 16 bits
#locate state   = 0x34
#locate bitmask = 0x35
#locate flip    = 0x36
if(interrupt_enabled(GLOBAL))
   disable_interrupts(GLOBAL);
   gie_enabled = TRUE;
// Get the I/O Port address and the bitmask from
// the CCS pin number value.
io_port = ccs_pin >> 3;
bitmask = bitmask_table[ccs_pin & 7];
// Set TRIS = input.
#ifdef __PCM__
*(io_port | 0x80) |= bitmask;  // For 16F PICs
#ifdef __PCH__
*(io_port + 0x12) |= bitmask; // For 18F PICs
#asm
PULSINT:
#ifdef __PCM__
         movf    io_port, W      ; Get port
         movwf   FSR
#ifdef __PCH__
         movf    io_port, W      ; Get port lsb
         movwf   FSR0L
         movf    BYTE_PTR(io_port) +1, W   ; Get port msb
         movwf   FSR0H
         movf    bitmask,w
         clrf    flip            ; Preset state tracking
         btfss   state, 0        ; State tracking preset for flip
         movwf   flip            ; Set state to bit mask
         call    statecnt        ; Wait for idle state
         btfsc   STATUS, Z       ; If timeout then it's over
         goto    done
         call    statecnt        ; Wait for starting edge
         goto    done
         call    statecnt        ; Do the count
         goto    done
statecnt:
         movf    bitmask, W      ; Flip state each time through here
         xorwf   flip, F
#ifdef PULSIN_MAX
         movlw   ((-(PULSIN_MAX)) + 1)       ; Start counter -PULSIN_MAX + 1
         movwf   count
         movlw   (((-(PULSIN_MAX)) + 1) >> 8)
         movwf   BYTE_PTR(count) + 1
#else
         movlw    1
         movwf    count
         clrf     BYTE_PTR(count) + 1
statecntloop:                    ; Takes 10 usec
#ifdef __PCM__
         movf    INDF, W         ; 1 Read Port with INDF
#ifdef __PCH__
         movf    INDF0, W        ; 1 Read Port with INDF0
         andwf   bitmask, W      ; 1 Mask it with bitmask
         xorwf   flip, W         ; 1 Mix with desired state
         btfss   STATUS, Z       ; 2 / 1
#ifdef PULSIN_MAX
         goto    statecntexit    ; 0 / 2 No longer in state
#else
         return                  ; 0 / 2 No longer in state
         incf    count, F        ; 1 Increment counter
         btfsc   STATUS, Z       ; 1 / 2
         incfsz  BYTE_PTR(count) + 1, F   ; 1 / 2
         goto    statecntloop    ; 2 / 0
         return                  ; 0 / 2 Counter overflow
#ifdef PULSIN_MAX
statecntexit:
         movlw   PULSIN_MAX      ; Normalize count
         addwf   count, F
         movlw   PULSIN_MAX >> 8
         btfsc   STATUS, C
         addlw   1
         addwf   BYTE_PTR(count) + 1, F
         bcf     STATUS, Z       ; Indicate no overflow
         return
done:
#endasm
if(gie_enabled)
return(count);
For reference, here is the PicBasic COUNT command for CCS:
http://www.ccsinfo.com/forum/viewtopic.php?t=41877
