PWM Instruction
saeidjabbari
PWM Instruction
PostPosted: Sun Apr 18, 2010 4:06 pm     Reply with quote
Hi
I want to know what is difference between two modes of PWM instruction?
setup_ccp1(CCP_PWM);
set_pwm1_duty(value);
setup_timer_2(T2_DIV_BY_16,PR,1)
and
setup_power_pwm(modes, postscale, time_base, period,compare,compare_postscale, dead_time)
set_power_pwm_override(pwm, override, value)
setup_power_pwm_pins(module0,module1,module2,module3)
PostPosted: Sun Apr 18, 2010 5:21 pm     Reply with quote
The first set is used with the ordinary PWM module (CCP) in a PIC.
The 2nd set is used with the Power Control PWM module.
This module has many more features than the ordinary PWM
module (CCP) and it is specifically designed to control motors.
saeidjabbari
PostPosted: Mon Apr 19, 2010 4:17 am     Reply with quote
Thanks A lot PCM programmer
