transfer waveforms into PC by Max232
alarassi
PostPosted: Sat Apr 17, 2010 4:04 am     Reply with quote
hello guy
I'm developing a GLCD oscilloscope project that I found online and I have done it successfully!
I want to transfer the data or waveforms into PC by using MAX232 but I have never used Max232 before!
I have interfaced the PIC to Max232 but I really don't know what I need to do to transmit that data and display it on PC!
Can you help me by guidance, example codes and the steps I should follow ?
Thank you
PostPosted: Sat Apr 17, 2010 11:52 am     Reply with quote
Here are instructions for downloading and installing a Terminal
program called TeraTerm. This program runs on your PC and
sends and receives serial data to/from the PIC.
http://www.ccsinfo.com/forum/viewtopic.php?t=39388&start=18
Here is the CCS FAQ article on RS-232 problems:
http://www.ccsinfo.com/faq.php?4
Here is a schematic of a MAX232 circuit:
http://web.ukonline.co.uk/j.winpenny/pic/rs232x.gif
Note that if you're using a MAX232A, then you should use 0.1 uF
capacitors, instead of the 1 uF caps.
This thread discusses how to send an array of bytes to the PC.
http://www.ccsinfo.com/forum/viewtopic.php?t=33383
