Frequency Interrupt
aaronik19
Frequency Interrupt
PostPosted: Mon Mar 11, 2013 8:34 am     Reply with quote
I am in a middle of a project and currently I am facing a problem with the interrupt Service Routine ISR. I made some test code below:
#include <frequency.h>
#define LCD_ENABLE_PIN PIN_A1
#define LCD_RS_PIN PIN_A3
#define LCD_RW_PIN PIN_A2
#define LCD_DATA4 PIN_D4
#define LCD_DATA5 PIN_D5
#define LCD_DATA6 PIN_D6
#define LCD_DATA7 PIN_D7
#include <lcd1.c>
int zc_count, period_read = 0;
#int_TIMER1
void  TIMER1_isr(void)
#int_TIMER2
void  TIMER2_isr(void)
#int_TIMER3
void  TIMER3_isr(void)
#int_EXT
void  EXT_isr(void)
  zc_count++;
  if (zc_count == 3)
   period_read = get_timer1();
   set_timer1(0);
   zc_count = 0;
#int_EXT1
void  EXT1_isr(void)
void setup()
   set_tris_a(0x00);
   set_tris_b(0x01);
   set_tris_c(0xff);
   set_tris_d(0x00);
   set_tris_e(0x00);
   output_a(0x00);
   output_b(0xfd);
   output_c(0x00);
   output_d(0x00);
   output_e(0x00);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);      //104 ms overflow
   enable_interrupts(INT_TIMER3);
   enable_interrupts(INT_EXT);
   enable_interrupts(INT_EXT1);
   lcd_init();
   delay_ms(6);
   lcd_gotoxy(4,1);
   lcd_putc("Welcome");
   setup();
for the time being please on focus on the EXT ISR, ignore the rest.
To test I am feeding an input on RB0 but the routing is not being executed.
#int_EXT
void  EXT_isr(void)
  zc_count++;
  if (zc_count == 3)
   set_timer1(0);
   zc_count = 0;
I checked everything twice but still nothing is working for the interrupt. Can somebody help me?
PostPosted: Mon Mar 11, 2013 9:26 am     Reply with quote
You are doing a port wide output on portB after setting the TRIS. This will set the tris on the whole port as _output_, so B0, can't work as an interrupt input.
aaronik19
PostPosted: Mon Mar 11, 2013 11:29 am     Reply with quote
Thanks Telmah. That was the problem. Everything is working now. In my example, I have put the RB0 (bit1) as "1" and the other bits as output "0". So if I have bit 6 and bit 7 as outputs how I can deal with this in TRIS?
asmboy
PostPosted: Mon Mar 11, 2013 11:47 am     Reply with quote
covered in user manual
SherpaDoug
PostPosted: Mon Mar 11, 2013 11:49 am     Reply with quote
1) Output individual bits to port B instead of the whole port.
2) Use TRIS after setting port B so the Int bit is an input.
3) Use fixed_IO instead of TRIS.
4) Use bit_test() to set the Int bit as an input
