pic 16f877A problem
ahmeddragonbleu
pic 16f877A problem
PostPosted: Sat Apr 10, 2010 5:32 am     Reply with quote
my program is not repeated. there is no loop
#include <16F877A.h>
#use delay(clock=4000000,restart_wdt)
void a()
output_b(0b00000000);
output_a(0b00000001);
delay_ms(1);
output_b(0b01110110);
output_a(0b00000010);
delay_ms(1);
output_a(0b00000100);
delay_ms(1);
output_a(0b00001000);
delay_ms(1);
output_a(0b00100000);
delay_ms(1);
void b()
delay_ms(1);
output_b(0b00110110);
delay_ms(1);
delay_ms(1);
delay_ms(1);
output_b(0b01001001);
delay_ms(1);
int j;
for(j=0;j<250;j++)
a() ;
for(j>250;j<500;j++)
b();
i need some help
PostPosted: Sat Apr 10, 2010 6:57 am     Reply with quote
When posting code use the 'code' button. This helps to preserve the layout of your program and makes for easier reading.
When you are having problems with your program always try to narrow down as much as possible. By removing as many parts as possible you will finally have a small (not working) program. This helps you to focus on where the real program is, instead of where you _think_ the program is.
What oscillator are you using? Crystal, clock generator, R-C?
Assuming you are using an external crystal change the start of your program to:
#fuses XT, NOLVP, NOWDT
A second problem is with variable 'j'. This is now declared as int but in the CCS compiler this equals to int8. An int8 has a maximum value of 255. You'll have to change it to an int16.
... and last:
This compiles but I'm not sure what code it will generate. Change to
for(j=250;j<500;j++)
ahmeddragonbleu
PostPosted: Sat Apr 10, 2010 9:29 am     Reply with quote
Thanks a lot for your help.
Now my program is running very well.
