External Interrupt have no effect on PWM?
kolopipo
PostPosted: Sat Apr 03, 2010 9:27 am     Reply with quote
My code for some simple program is as shown
#include <18F4431.h>
#use delay(clock=10000000)
#fuses NOWDT, HS, NOPROTECT, NOLVP, NOPWMPIN, HPOL_HIGH, LPOL_HIGH
#INT_EXT
void  EXT_isr(void)
   while(1){
      if(input(PIN_C4))
            output_high(PIN_D0);
            output_low(PIN_D0);
// interrupt function for pin INT1
#int_EXT1
void  RB_isr(void)
   output_high(PIN_D1);
   output_low(PIN_D1);
   enable_interrupts(INT_EXT); //enable interrupt function int_ext
   ext_int_edge(0,L_TO_H );      // Sets interrupt at int0 detect low to high edge
   enable_interrupts(INT_EXT1); // enable interrupt function int_ext1
   ext_int_edge(1,L_TO_H ); // sets interrupt at int1 detect low to high edge
   enable_interrupts(GLOBAL); //enable all interrupts (MUST after enable_interrupts() !!)
   set_tris_c(0xFF); //set port cinput
   set_tris_d(0x00); // set port doutput
   setup_timer_2(T2_DIV_BY_4,99,1);
   setup_ccp1(CCP_PWM);
      set_pwm1_duty(50);
I don't understand why the ccp pin still got the pwm signal when it is interrupted? The program still do the interrupt functions but the void main program which has pwm program is still running. The registers for pwm are not cleared during interupt? I thought interrupt will stop the void main program temporarily until the interrupt is done.
SherpaDoug
PostPosted: Sat Apr 03, 2010 9:42 am     Reply with quote
As long as the timer is running it will generate the PWM output. It has no relation to what the CPU is doing, so interrupts that don't meddle with the timer have no effect on PWM.
