John A.D.M
| Bit Array unsupported! |
Posted: Tue Mar 30, 2010 12:08 pm |
Good Evening,
I am trying to employ a bit array but am experiencing in-compatibility.
#include <16F887.h>
#fuses NOLVP, RC, NOWDT, NOPROTECT, NOCPD //#fuses HS, NOWDT, NOLVP, BROWNOUT, NOPROTECT, PUT
#use delay(clock=4000000) // 4MHz
boolean bool[4];
int i=0;
This will create an array of bits, and initialize their values
int1 flags[]={TRUE, TRUE, TRUE, FALSE, FALSE, FALSE};
Some usages:
bool[2] = flags[1];
if ( flags[2] ) { /* do something */ }
flags[i++] = FALSE;
This example was adopted from the CCS website.
It does not seem to function on the PIC16F887 and MPLAB Sim report the bit array as an "unsupported structure".
All help is appreciated....
MPLAB Version: 8.46.00.00
CCS PCWH (PCM,PCB, PCH, IDE) 4.087
Thanks. |
Posted: Tue Mar 30, 2010 12:36 pm |
You didn't make a test program that displayed the results, so I made one
for you. I installed vs. 4.087 and ran the program below and got these
results, which are correct:
| Quote: |
bool[2] = 1
flags[2] = 1
flags[0] = 0
| Quote: |
CCS and Microchip are two different companies. There is no requirement
that Microchip support CCS constructs, such as bit arrays.
#include <16F887.h>
#fuses XT, NOLVP, NOWDT, NOPROTECT, NOCPD
boolean bool[4];
int i=0;
Some usages:
bool[2] = flags[1];
printf("bool[2] = %u\r", bool[2]);
if(flags[2])
/* do something */
printf("flags[2] = %u\r", flags[2]);
flags[i++] = FALSE;
printf("flags[0] = %u\r", flags[0]);
