Baesy
Push-Button Interrupt |
Posted: Thu Mar 25, 2010 6:16 am |
Hello
I work with the PIC16F883 and I have a problem. By the inputs RB5 and RB6 I have two pushbuttons with pull-down resistors. Now I want to have two interrupt routines, one for the input RB5 and one for the input RB6. I wrote the following code, but it doesn't work.
#fuses HS, NODEBUG, NOBROWNOUT, NOPROTECT, MCLR, NOPUT, NOFCMEN, WDT
#fuses NOLVP, NOWRT, NOIESO, NOCPD,
#use delay (clock=8000000)
//Funktions-Prototypen
void InitPorts (void);
void InitTimer0 (void);
void InitTasterInt (void);
void InitADC (void);
void ReadADC (void);
//Globale Variabeln
unsigned char Lautsprecher = 0;
void main (void)
InitPorts();
InitTasterInt();
}//while(1)
/* InitPorts
SET_TRIS_A(0x2F); //Eingänge und Ausgänge definieren
SET_TRIS_B(0x00);
SET_TRIS_C(0xCF);
/* Interrupt vom RB5: Einlese-Taster
#INT_RB5
void InterruptTasterRB5 (void)
/* Interrupt vom RB6: Taster Neue Kiste
#INT_RB6
void InterruptTasterRB6 (void)
/* InitTasterInt
ENABLE_INTERRUPTS(GLOBAL);
ENABLE_INTERRUPTS(INT_RB5);
ENABLE_INTERRUPTS(INT_RB6);
Could somebody help me please.
PS: Sry for my english, I'm a young swiss student. :-D |
turantus
Posted: Thu Mar 25, 2010 11:41 am |
Maybe the watchdog resetting you all time? |
mbge5amw
Joined: 13 Dec 2004 Posts: 15 Location: Yorkshire, UK
Posted: Mon Mar 29, 2010 8:44 am |
TRIS needs to be set high on a pin for it to be read as an input.
I am also not sure if the way you have the switch wired would work,it may eb worth checking the voltage on the input pin.
Not sure if you can drive a low input with a weak pull down resistor, I've always been taught that TTL circuits should have a weak pull up and a strong pull down. i.e. your push button goes to ground and your resistor (1k to 10k would be fine) goes to VCC.
Andy |
