10F206 not running.......
Jody
PostPosted: Thu Mar 25, 2010 7:17 am     Reply with quote
Hello, I am trying to get my small PIC the 10F206 to toggle some outputs.
In fact I want to control a servo.
When I connect a scope to it it doesn't show any activity.
What am I doing wrong??
#include <10F206.h>
#FUSES NOWDT                      //No Watch Dog Timer
#FUSES NOMCLR                     //Master Clear pin: disable
#FUSES NOPROTECT                  //No code protected from reads
#byte STATUS = 0x003
#bit  DC = STATUS.1
#bit  PD = STATUS.3
#bit  TO = STATUS.4
#bit  GPWUF = STATUS.7
#byte GPIO = 0x006
#bit  GP0 = GPIO.0 //SWITCH
#bit  GP1 = GPIO.1 //FET
#bit  GP2 = GPIO.2 //SERVO
#bit  GP3 = GPIO.3 //MCLR
int1 PinChangeFlag;
int16   i;
void Init()
    output_high(GP1); //servo enable
main()
    PinChangeFlag = GPWUF;
    setup_comparator(NC_NC);
    while(true)
        Init();
                for(i=0; i <400;i++)//linksom
                    output_high(GP2);
                    delay_us(500);
                    output_low(GP2);
                    delay_ms(10);
            for(i=0; i <400;i++)//rechtsom
                output_high(GP2);
                delay_us(1200);
                output_low(GP2);
                delay_ms(10);
PostPosted: Thu Mar 25, 2010 7:50 am     Reply with quote
The output_high instruction, expects a pin definition, _not_ a bit defintion. These are already 'in' the include file for the processor.
So your 'init' becomes:
void Init()
    output_high(PIN_B1); //servo enable
And similarly for all the other output_high, and output_low instructions.
Jody
PostPosted: Thu Mar 25, 2010 9:19 am     Reply with quote
Thanks!!!
I will check it when I get back to the office.....
I will keep you informed...
Regards,
Jody
Jody
PostPosted: Fri Mar 26, 2010 2:50 am     Reply with quote
It works thanks!!!!!!!
