How to check if RS232 Stream is defined
SpaceXDebris
PostPosted: Thu Mar 25, 2010 1:52 pm     Reply with quote
Hey there,
This is possible:
#define FOO 1
#ifdef FOO
//Code
#endif
I'm trying to do the something similar with rs232 streams. Ideally:
#use rs232(... STREAM=COM_A)
#use rs232(... STREAM=COM_B)
//Code
#ifdef COM_A
#ifdef COM_B
// Code that only compiles when two streams are defined
#endif
#endif
#ifdef obviously doesn't work in this case. Is there something similar I could do? It would be especially helpful if users of my lib wouldn't have to change their application code, so I'd like to not have to require them to #define other variables if they are using two streams, but I guess I could last resort.
Thanks as always for the help, and I apologize if this solution was posted elsewhere. I did a quick search and came up empty.
Chris
PostPosted: Thu Mar 25, 2010 10:15 pm     Reply with quote
The #if defined() syntax works with vs. 4.105. It can detect if a stream
is defined or not. Use it instead of #ifdef. Example:
#include <16F877.H>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS, stream=COM_A)
#use rs232(baud=9600, xmit=PIN_B1, rcv=PIN_B2, ERRORS, stream=COM_B)
int8 c;
#if defined(COM_A)
c = 0x55;
#else
c = 0xAA;
#endif
