dsPIC30 RAM-use Problems
P51D
PostPosted: Mon Feb 08, 2010 4:53 am     Reply with quote
Hello all
I've some interessting problems with the ram-pointer and usage.
if I execute only the main parts, it works. Then I try to add some big arrays:
int8 delay[600]={...};
int16 dac1[600]={...};
int16 dac2[600]={...}:
Now works only the half of the program. An LCD-output function shows nothing on the lcd and the dac have also not every value.
For example:
DAC_output(dac1[p] | (1<<12) | (1<<13));
1_DAC_select;
deselect;
DAC_output(dac2[p] | (1<<12) | (1<<13));
2_DAC_select;
deselect;
if(p == 150) p = 0;
else p ++;
The dac has array values from place 0 to ~350 and not 0,1,2,3,4....
it seems like 0,3,4,6,9,...
What is the problem?
The fuses are this way:
#device DSPIC30F6012A *=16      //16Bit Ram Pointer
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES PR                       //Promiary Oscillator
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES WPSB1                    //Watch Dog Timer PreScalar B 1:1
#FUSES WPSA1                    //Watch Dog Timer PreScalar A 1:1
#FUSES PUT64                    //Power On Reset Timer value 64ms
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES LPOL_HIGH                //Low-Side Transistors Polarity is Active-High (PWM 0,2,4 and 6)
   //PWM module low side output pins have active high output polar
#FUSES HPOL_HIGH                //High-Side Transistors Polarity is Active-High (PWM 1,3,5 and 7)
   //PWM module high side output pins have active high output polarity
#FUSES NOPWMPIN                 //PWM outputs drive active state upon Reset
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOCOE                    //Device will reset into operational mode
#FUSES ICS0                     //ICD communication channel 0
#FUSES RESERVED                 //Used to set the reserved FUSE bits
Thanks for answering.
best regards
P51D
HYDERABADII
dispic30f6012a configuration settings problem
PostPosted: Fri Mar 26, 2010 3:52 am     Reply with quote
Hello sir,
I'm using dspic30f6012a with your CCS pcwhd v4.093. This one worked well for 16f877a but with dspic30f6012a it is not showing any output. Here is the code.
I want to run this code with fast RC oscillator.
#include <30F6012a.h>
#FUSES FRC               //Primary Oscillator with PLL
#FUSES PUT4                    //Power On Reset Timer value 4ms
#FUSES NOBROWNOUT               //No Brownout reset
#FUSES NOMCLR                   //Master Clear pin used for I/O
//#FUSES ICS0                     //ICD communication channel 0
#use delay(clock=7.37MHZ)
OUTPUT_B(PIN_B0|PIN_B1);
OUTPUT_F(PIN_F4 | PIN_F5);
SET_TRIS_b(PIN_B0|PIN_B1);
SETUP_ADC_PORTS(NO_ANALOGS);
while (true)
OUTPUT_LOW(PIN_B1);
OUTPUT_LOW(PIN_B0);
OUTPUT_LOW(PIN_F4);
OUTPUT_LOW(PIN_F5);
OUTPUT_HIGH(PIN_B1);
OUTPUT_HIGH(PIN_B0);
OUTPUT_HIGH(PIN_F4);
OUTPUT_HIGH(PIN_F5);
Plzz reply me as early as possible.
Thank you.
PostPosted: Fri Mar 26, 2010 6:09 am     Reply with quote
I don't see a problem with V4.093 and your code. It's working with MPLAB, thus I expect a hardware problem.
