PCD: Problem calling functions inside infinite loop
dima2882
PostPosted: Sun Mar 21, 2010 4:59 pm     Reply with quote
I'm hoping this is something silly, 'cause I'm stumped. I'm using 4.099, have the following test project:
#include <24F04KA200.h>
// Do some configuration
#fuses NOPROTECT, FRC, OSCIO, NOWDT, NOBROWNOUT, NOMCLR, NODSBOR, NODSWDT, NOWRT, NOWINDIS, NOPUT
#use delay(internal=8MHz)
#use fast_io(ALL)
// Function prototypes
void doDelay(void);
// Function does nothing
void doDelay(void)
   output_low(PIN_B9);
   output_low(PIN_B15);
   output_low(PIN_A6);
   delay_us(20);
   output_high(PIN_B9);
   output_high(PIN_B15);
   output_high(PIN_A6);
   delay_us(20);
   return;
   // Disable all analog pins as they are unneccessary for this application
   setup_adc_ports(NO_ANALOGS);
   // Set up the I/O lines
   set_tris_a(0x32);
   set_tris_b(0x4000);
   //output_high(PIN_B9);
   //output_high(PIN_B15);
   //output_high(PIN_A6);
   do {
      doDelay();
      output_low(PIN_B9);
      output_low(PIN_A6);
      delay_us(20);
      delay_us(20);
   } while (TRUE);
   return;
When the doDelay function is commented out of the do-while loop, things work fine, I see a square wave on the three output pins. When I leave it in, like above, nothing works - the lines stay low. What could be the problem?
Some more weirdness: if I uncomment the code that sets the three lines high BEFORE going into the infinite do-while, then what I see on the scope is almost a square wave with a very high duty cycle... It's as if the MCU reboots continuously, causing the lines to go low momentarily.
dima2882
PostPosted: Mon Mar 22, 2010 9:19 am     Reply with quote
Anybody? Bueller?
Plz, I really got to have this app working!
PostPosted: Mon Mar 22, 2010 12:56 pm     Reply with quote
There are only a couple people on this forum that normally answer PCD
questions. If they're not on here, you won't get a quick reply.
I don't have the PCD compiler, but the first thing I would do is to reduce
the program size.
1. Functions automatically return. You don't need a 'return' statement
at the end, unless the function is declared to return a value, and yours
don't. Remove the returns. Also, there is no Operating System for
main() to return to. Just put a continuous while(1) loop at the end of
main() or in your program. Delete the 'return'.
2. Get rid of #fast_io mode and the set_tris_x() statements, and let
the compiler set the TRIS.
3. Just toggle one pin, for example, Pin B9. See what happens.
dima2882
PostPosted: Mon Mar 22, 2010 1:06 pm     Reply with quote
Do I need a #use standard_io statement for the port I want to use? That's now the way I changed it. Going to go try it now...
PostPosted: Mon Mar 22, 2010 1:16 pm     Reply with quote
The PCD manual says:
Standard_io is the default I/O method for all ports.
So, you don't need one.
dima2882
PostPosted: Mon Mar 22, 2010 6:34 pm     Reply with quote
Reinstalled the compiler... Everything worked the way it is written in the listing of my original post. I guess something in Windows went to hell :(
