gets() not working with PIC18LF2550
big_nige
PostPosted: Fri Mar 19, 2010 11:06 pm     Reply with quote
Hi All,
Using PCHL 4.101; 7/1/2009
gets() seems to be hanging and I am not sure what is going on.
Test code:
#include <18F2550.h>
#fuses INTRC_IO,CPUDIV1,NOWDT,NOPROTECT
#use delay(clock=8MHZ,RESTART_WDT)
#use rs232(uart1, baud=57600)
void main() {
   char cmd[30];
   while (TRUE){
      printf("enter string: ");
      //cmd[0] = getc();
      gets(cmd);
      printf("you entered: %s(%x)\r\n", cmd, cmd[0]);
this code locks up does not detect RETURN (0x0D).
test code 2:
void main() {
   char cmd[30];
   while (TRUE){
      cmd[0] = getc();
      //gets(cmd);
This code accepts characters fine, for example if you hit 'e' it prints out:
'you entered: e(65)'
And if you hit the enter key, it prints:
'you entered: (0D).
So my serial link is working, and the chip detects a return, but the gets() does not.
Any ideas?
Cheers,
Nigel
PostPosted: Sun Mar 21, 2010 2:00 pm     Reply with quote
You're using the Linux version of the compiler. I don't think the version
numbers of the Linux compiler track with the Windows version. So I
don't think I can duplicate your environment.
Can you compile a stripped down version of your code, as shown below,
and post the .LST file. Then I can look at it and see if it's doing
something wrong.
char cmd[30];
   gets(cmd);
   printf("%s(%x)\r\n", cmd, cmd[0]);
big_nige
PostPosted: Mon Mar 22, 2010 12:59 am     Reply with quote
As requested:
CCS PCH C Compiler, Version 4.101, 51450               22-Mar-10 17:56
               Filename: /home/nigel/redearth/smseries/test_ccs.lst
               ROM used: 218 bytes (1%)
                         Largest free fragment is 32550
               RAM used: 34 (2%) at main() level
                         36 (2%) worst case
               Stack:    1 locations
0000:  GOTO   0060
.................... #include <18F2550.h>
.................... //////// Standard Header file for the PIC18F2550 device ////////////////
.................... #device PIC18F2550
.................... #list
.................... #fuses INTRC_IO,CPUDIV1,NOWDT,NOPROTECT
.................... #use delay(clock=8MHZ,RESTART_WDT)
.................... #use rs232(uart1, baud=57600)
.................... void main()
0060:  CLRF   FF8
0062:  BCF    FD0.7
0064:  CLRF   FEA
0066:  CLRF   FE9
0068:  MOVLW  70
006A:  MOVWF  FD3
006C:  MOVF   FD3,W
006E:  BSF    FB8.3
0070:  MOVLW  22
0072:  MOVWF  FAF
0074:  MOVLW  00
0076:  MOVWF  FB0
0078:  MOVLW  A6
007A:  MOVWF  FAC
007C:  MOVLW  90
007E:  MOVWF  FAB
0080:  MOVF   FC1,W
0082:  ANDLW  C0
0084:  IORLW  0F
0086:  MOVWF  FC1
0088:  MOVLW  07
008A:  MOVWF  FB4
.................... char cmd[30];
.................... while(1)
....................    gets(cmd);
008C:  CLRF   FEA
008E:  MOVLW  05
0090:  MOVWF  FE9
0092:  DECF   FE9,F
0094:  BTFSS  F9E.5
0096:  BRA    0094
0098:  MOVFF  FAE,FEE
009C:  MOVLW  0D
009E:  SUBWF  FEF,W
00A0:  BNZ   0092
00A2:  CLRF   FEF
....................    printf("%s(%x)\r\n", cmd, cmd[0]);
00A4:  CLRF   FEA
00A6:  MOVLW  05
00A8:  MOVWF  FE9
00AA:  BRA    0004
00AC:  MOVLW  28
00AE:  BTFSS  F9E.4
00B0:  BRA    00AE
00B2:  MOVWF  FAD
00B4:  MOVFF  05,23
00B8:  MOVLW  57
00BA:  MOVWF  24
00BC:  BRA    001C
00BE:  MOVLW  29
00C0:  BTFSS  F9E.4
00C2:  BRA    00C0
00C4:  MOVWF  FAD
00C6:  MOVLW  0D
00C8:  BTFSS  F9E.4
00CA:  BRA    00C8
00CC:  MOVWF  FAD
00CE:  MOVLW  0A
00D0:  BTFSS  F9E.4
00D2:  BRA    00D0
00D4:  MOVWF  FAD
00D6:  BRA    008C
00D8:  SLEEP
Configuration Fuses:
   Word  1: C827   INTRC_IO IESO FCMEN PLL12 CPUDIV1 USBDIV
   Word  2: 1E3E   BROWNOUT NOWDT BORV20 PUT WDT32768 VREGEN
   Word  3: 8700   PBADEN CCP2C1 MCLR LPT1OSC
   Word  4: 0081   STVREN NODEBUG NOLVP NOXINST
   Word  5: C00F   NOPROTECT NOCPD NOCPB
   Word  6: E00F   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTR NOEBTRB
Cheers,
Nigel
PostPosted: Mon Mar 22, 2010 1:47 am     Reply with quote
I think gets() is buggy in your version. Try using get_string() in input.c
instead. The input.c file is in the CCS drivers directory. get_string()
requires that you supply the maximum buffer length.
big_nige
PostPosted: Mon Mar 22, 2010 2:35 am     Reply with quote
yeah - that fixed it.
I tried my own quick-and-dirty getc loop testing for ENTER key and it works too - so I would agree that there is a bug in the compiler somewhere.
Thanks for your help.
Nigel
