No timer1 defines in H file for 18FJ4611
Chibouraska
PostPosted: Mon Mar 22, 2010 1:58 pm     Reply with quote
Hi!
I updated to 4.105 PCWHD compiler and there is no defines for timer1 in the header file for the PIC18F46J11 so i get an error in my program. How come and what should i do. Thanks
AC
PostPosted: Mon Mar 22, 2010 2:05 pm     Reply with quote
You're right. I installed vs. 4.104, and it has these constants.
You can edit your .h file, and add these to it.
But make sure you email CCS support and tell them about the bug
in vs. 4.105.
////////////////////////////////////////////////////////////////// Timer 1
// Timer 1 Functions: SETUP_TIMER_1, GET_TIMER1, SET_TIMER1
// Constants used for SETUP_TIMER_1() are:
//      (or (via |) together constants from each group)
#define T1_DISABLED         0
#define T1_INTERNAL         0x07
#define T1_INTERNAL_TIMES_4 0x47
#define T1_EXTERNAL         0x87
#define T1_EXTERNAL_SYNC    0x83
#define T1_CLK_OUT          8
#define T1_DIV_BY_1         0
#define T1_DIV_BY_2         0x10
#define T1_DIV_BY_4         0x20
#define T1_DIV_BY_8         0x30
Chibouraska
PostPosted: Mon Mar 22, 2010 2:29 pm     Reply with quote
Thanks PCM! your always a great help. I will email support.
Charlie U
PostPosted: Mon Mar 22, 2010 3:01 pm     Reply with quote
I reported this to CCS regarding the missing parameters in the 16F1937.h files. I received an email from Darren stating that this will be corrected in V4.106 which will be released either today or tomorrow.
bkamen
PostPosted: Tue Mar 23, 2010 10:33 pm     Reply with quote
4.106 was released today.
Interestingly, these are the values for timer1
#define T1_INTERNAL         0x05
#define T1_FOSC             0x45
#define T1_GATE           0x8000
#define T1_GATE_INVERTED  0xC000
#define T1_GATE_TOGGLE    0xA000
#define T1_GATE_SINGLE    0x9000
#define T1_GATE_TIMER0    0x8100
#define T1_GATE_COMP1     0x8200
#define T1_GATE_COMP2     0x8300
-Ben
Charlie U
PostPosted: Wed Mar 24, 2010 11:03 am     Reply with quote
Hi Ben,
Why do you say "interestingly"? Are these wrong? At first glance, they look correct. There are definitely some new ones vs 4.104.
Charlie
bkamen
PostPosted: Wed Mar 24, 2010 12:33 pm     Reply with quote
Look at the different between the 2.. a couple #defines have different values AND the names.
Charlie U
PostPosted: Wed Mar 24, 2010 3:01 pm     Reply with quote
I must be the one that is "dazen and confused". I was just looking at them from the definition stand point, not the delta from 4.104 to 4.106. Anyway, let's hope that these are correct and won't change in another release. I am off to check the 16F1937.h file now to see if it is correct for my project.
