receiving garbage from SPI MISO
PaulW
PostPosted: Wed Mar 17, 2010 1:46 pm     Reply with quote
CCS PCH C Compiler, Version 4.011, 32099
PIC18F6722
MCP23S17 http://ww1.microchip.com/downloads/en/DeviceDoc/21952b.pdf
Problem:
I'm trouble shooting a problem with SPI port 2 on PIC.
Conditions:
Existing project has trouble reading SPI port 2. It's using bit banging. RX signals look good, but Data isn't reliable.
What I've tried:
Wrote small project (see below) to test SPI 2. I'm Using CCS canned SPI access functions. It compiles and runs. My CS, CLK, Data out looks great. Slave Out data is at correct sequence, but logic levels look bizarre.
Both of these projects are running on the same board.
What I'm trying to accomplish: Write a small test program that will simple read from GPIO A and GPIO B, that I can use to verify that: 1. Hardware works. 2. Figure out what is wrong in existing Project.
Does this code look right?
#include <18F6722.h>
#define GPIO_EXTENDER_CS  PIN_D3
// SPI modes
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
void GPIO_Write_Register(int8 reg, int8 data)
   int16 temp;
   output_low(GPIO_EXTENDER_CS);
   temp = ((reg & 0x3F) << 1) | 0x40;  // write to address 0x42 - (for debugger watch)
   spi_write2(temp);                   // set up address
   spi_write2(data);                   // send data
   output_high(GPIO_EXTENDER_CS);
int8 GPIO_Read_Register(int8 reg)
int8 data;
   spi_write2((((reg & 0x3F) << 1) | 0x01) | 0x40);   // send read address to 0x42
   data = spi_read2(0);                               // read
   return(data);
int8 result;
int8 Xdata, Ydata, Zdata;
   delay_ms(10);   // Minimum 1 ms required after power-up.
   setup_spi2(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_16);  // 1.25 MHz sclk
//   Acc_Write_Register(0x1, 0x12);
   delay_ms(30);  // Minimum 20 ms required after exiting standby
   for(;;)
      GPIO_Write_Register(0x1, 0x12);           // set register pointer to 0x12
      Xdata = GPIO_Read_Register(0x01);         // read from register 0x12
      Ydata = GPIO_Read_Register(0x01);         // read from register 0x13
I have a screen shot of the data out, if anyone interested. Thanks.
PostPosted: Wed Mar 17, 2010 2:04 pm     Reply with quote
If the logic levels look weird, then look for two output pins that are
connected together (or shorted), and are fighting each other.
PostPosted: Wed Mar 17, 2010 3:05 pm     Reply with quote
Version 4.011
Besides the likely electrical problems, your compiler version is highly unstable. It has been mentioned many times on this forum: don't use any v4.0xx compiler older than v4.070
These were alpha quality releases of the new compiler and should never have been released without a huge neon warning message.
Save everybody, yourself included, a lot of time by upgrading to a new compiler or downgrade to the stable v3.249 that was available at the time of your v4.011 download.
PaulW
PostPosted: Wed Mar 17, 2010 3:22 pm     Reply with quote
That's what it looks like to me too, but I can find no cross talk. I've tripled checked everything. No shorted pins on the chip in place. With Everything connected, there is no shorted pins either.
The chip seems to be responding to requests, but it's wacky. It's like cap limited, (or something). Slave Out goes high, then writes, but peters out, and slews down to zero again.
My Problem is though:
The Chip output levels look good when bit banged. ???
The Chip output looks really strange with the above code. ???
The only difference is Software. ???
It's the same board. Same connections. And I tried it on two other boards too. They all do the same thing, and behave differently with the two softwares installed.
Does the above code look reasonable?
I'm thinking It's probably the chip setup somehow.
Thank you.
PaulW
PostPosted: Wed Mar 17, 2010 3:23 pm     Reply with quote
@ckielstra, Thanks. I do have that version and will try it too.
PostPosted: Wed Mar 17, 2010 3:34 pm     Reply with quote
Post a list of the connections between the PIC and the MCP23S17.
Look at the physical wires (or tracks) on the board and post the
pin-to-pin list of connections, taken by direct visual observation.
Don't post the signal names. Post the pins.
a3ka2000
PostPosted: Thu Mar 18, 2010 1:53 am     Reply with quote
Hi, just a question, for some PIC model that does not have SPI_XMIT_L_TO_H defined in the header file, does that mean that it's not available? How to define SPI Mode0 then?
